Prove divisibility, mathematical induction
8 replies · 3K views · last reply
Jaroslav
I'm still learning English, had to use dictionary and translator, so I'm sorry if its unclear, i will try to explain it more if needed.
For n belonging to N when n is even and n > 3, prove that
(4^(n-3) + 5^(n-3) + 9) is divisible by 9
3. The Attempt at a Solution
[/B]
P(n) = 4^(n-3) + 5^(n-3)+9
for n = 4 :
P(4) = 4^1 + 5^1 + 9 = 18, divisible by 9
Now assume that n=k, P(k) = 4^(k-3) + 5^(k-3)+9 is div by 9, then solve it for P(k+2) = 4^(k-1) + 5^(k-1)+9
And here is the problem, i know that i should use assumption from n=k, but i really don't know how. I have problem with rearranging things to involve it...this is what i tried to use somehow, but always get stuck without any clear step forward
4^(k-3) + 5^(k-3)+9 = 4^(-2)*4^(k-1)+5^(-2)*5^(k-1)+9 = 9m
Somehow i wanted to get that (k-1) exponent from it, but i can't deal with multipliers there
You should be working the other way around: try to rewrite P(k+2) in terms of quantities that you know are divisible by ##9##. Here's a good starting point: ##4^{k-1} + 5^{k-1} = 16\left(4^{k-3}\right) + 25 \left(5^{k-3}\right)##
and note that by our inductive hypothesis, ##4^{k-3} + 5^{k-3}## is divisible by ##9##.
[/B]
for n = 4 :
First, the question seems strange, as the ##+9## isn't doing anything and why start with ##n = 4## then use ##n-3##? Why not just start with ##n = 1## and prove it for odd ##n##?
Anyway, have you thought of using ##mod \ 9##?
The task is more complicated, at start i had a story about hero who fights a hydra, and each "round" he cut off all her heads, except black, and after that more heads of different colours grow up. Long story short, after little programming and some assuming i made this formula and domain of a function myself. 9 is number of black heads that can not be cut down, and i start at n = 4 because its first round when number of head is divisible by 9
Well, perhaps don't worry about that! See post #2.
Hypotesis is that 4k−3+5k−3 + 9 is div by 9, so i want to ask, is it mathematicaly correct to assume that (number divisible by 9) + 9 is still divisible by 9? I know it might sound stupid, but our math proffesor is really...i can't find a word for it, just if i do any little mistake or something which is ilogical, i will be eaten alive.
And if yes, can i just write it without that 9? Or should i point it out somehow. Thanks for starting point anyway, I think I'm getting it now.
There is no need to assume - it is a given fact (that if you want to be rigorous, follows from division being right-distributive over addition and subtraction i.e. ##(a+b)/c = a/c + b/c##). Just let (number divisible by 9) be some integer multiple ##\lambda## of 9 and clearly adding 9 to it results in a multiple of 9.
If a number is divisible by ##9## and you add or subtract ##9## then the result is divisible by ##9##.
A useful way to express divisibility - in this case by ##9## - is:
##n## is divisible by ##9## if and only if ##n = 9k## for some integer ##k##
You could use this to prove the statement above formally.
Thank you, both of you really helped me to solve this, now i just add some small details and homework is complete :)
