Prove every convergent sequence of real numbers is bounded &
10 replies · 4K views
The question : http://gyazo.com/7eb4b86c61150e4af092b9f8afeaf169
Sup/Inf axioms
Methods of constructing sequences
##ε-N##
##lim(a_n) ≤ sup_n a_n## from question 5 right before it.
I'll split the question into two parts.
(a) We must prove every convergent sequence of real numbers is bounded. Suppose ##a_n## is a convergent sequence, that is ##lim(a_n) = L## where ##L \in ℝ##.
So for ## ε = 1, \exists N \space | \space n ≥ N \Rightarrow |a_n - L| < 1##
Thus ##-1 + L < a_n < 1 + L## so that ##a_n## is bounded below by -1 + L and above by 1 + L.
(b) Suppose ##lim(a_n) = L##, we must prove that ##inf_n a_n ≤ L ≤ sup_n a_n##
From question 5 prior, we already know that ##L ≤ sup_n a_n##
So we want to show ##inf_n a_n ≤ L##.
Assume the converse is true, that is suppose that ##inf_n a_n > L##.
Since ##inf_n a_n ≤ sup_n a_n##, we have that ##sup_n a_n ≥ inf_n a_n > L##, but this implies that ##sup_n a_n > L## which is a contradiction.
Part a)
This does not in general work. All you know is that for [itex]n\geq N[/itex], this bound is valid. What about for [itex]n<N[/itex]?
notice that a sequence {a[n]} is convergent if lim sup a[n] = lim inf a[n] = L. the idea is that as 'n' goes to infinity, the largest or smallest value in the 'tail' of the sequence approaches L monotonically [why?]. so if "inf a[n] > L" for some value of 'n', if must be true for all larger values of 'n'.
And for (b), what is the contradiction? There is no problem with ##\sup a_n > L##. Also, to make your posts more readable, use a backslash in front of keywords like inf, sup, lim.
christoff said:
Part a)
I'll address this first.
After some thought I believe i see what you're intending. I don't need to consider n<N. I just need to choose a different N, say ##N'##
(a) We must prove every convergent sequence of real numbers is bounded. Suppose ##a_n## is a convergent sequence, that is ##\lim(a_n) = L## where ##L \in ℝ##.
Thus ##-1 + L < a_n < 1 + L## so that ##a_n## is bounded below by -1 + L and above by 1 + L. This covers all cases of ##n ≥ N##.
Now, for some ##n < N## we can see that ##a_n > L + 1## so that ##L + 1## is not an upper bound so we define :
##M = max\{ max\{a_n \space | \space n < N\}, L + 1 \}## so we could bound ##a_n## as desired.
(b) Suppose ##\lim(a_n) = L##, we must prove that ##\inf_n a_n ≤ L ≤ \sup_n a_n##
From question 5 prior, we already know that ##L ≤ \sup_n a_n##
So we want to show ##\inf_n a_n ≤ L##.
Assume the converse is true, that is suppose that ##\inf_n a_n > L##.
We know ##\forall ε > 0, \exists N \space | \space n ≥ N \Rightarrow |a_n - L| < ε##
So for ##ε = \inf_n a_n - L## we have ## |L - a_n| < \inf_n a_n - L##
So we have ##-\inf_n a_n + L < a_n - L < \inf_n a_n - L## which yields ##a_n < \inf_n a_n## which is a contradiction.
##∴ \inf_n a_n ≤ \lim(a_n) ≤ \sup_n a_n## as desired.
OUT OF QUESTION : Is ##\sup_n a_n = limsup(a_n)##? Ditto for liminf?
(a) Suppose ##a_n## is a convergent sequence so that ##lim(a_n) = L##.
So we know ##\forall ε > 0, \exists N \space | \space n > N \Rightarrow |a_n - L| < ε##.
We want to show ##a_n## is bounded, that is we must show that ##|a_n| ≤ M## for some ##M \in ℝ##
So let's choose an ε. For ##ε = 1, \exists N' \space | \space n > N' \Rightarrow |a_n - L| < 1##
Now we can use the fact ##|x| - |y| ≤ |x - y|## so we get the inequality ##|a_n| - |L| ≤ |a_n - L| < 1##.
So we can take the portion of the inequality ##|a_n| - |L| < 1## and conclude that ##|a_n| < 1 + |L|##.
So choosing ##M = max\{a_n, 1 + |L| \space | \space n \in \mathbb{N}\}##, ( We have to consider all the terms in the sequence as well ) we can bound ##a_n## as desired.
Well, you took that hint completely the wrong way. I don't see what N' is buying you. You've already shown ##a_n## is bounded for n>N. All you have to worry about is n<=N. That isn't so hard to deal with is it? There are only a finite number of terms.
Dick said:
Well, you took that hint completely the wrong way. I don't see what N' is buying you. You've already shown ##a_n## is bounded for nN. All you have to worry about is n<N. That isn't so hard to deal with is it? There are only a finite number of terms.
Hmm you're right, now that I look back I see I didn't really need N', but why is my ##M## not good?
I'm not quite sure why I have to consider everything below a certain number when I'm considering all terms of the sequence as well as ##ε + |L|## for some positive ##ε##.
Also I added another try at part (b).
EDIT : I see I don't need my ##N_2## either now.
EDIT 2 : Wow facepalm, i just realized what n<N meant. I fixed my M accordingly.
EDIT 3 : Fixed all the errors now hopefully.
It's really hard to tell what you changed. It's still all a mess. Look, your initial try at part a) was almost correct. Just say what you are going to do with n<=N. You can't take the max over all ##a_n## until you shown it has a max. Otherwise you could have done that to begin with.
I dropped the unneeded N's and cleaned it up a bit.
Also my initial try? As in the one in my first post? I don't see how my most recent attempt is wrong considering I took ##M = \{|a_n|, 1 + |L| ... ## ( I wrapped ##a_n## in an abs ). This means that I consider all values of ##n \in \mathbb{N}##, not just values ##n ≥ N## ( I understand your issue is that I need to show ##a_n## is bounded for all n ). So I'm not convinced this is incorrect.
Considering my initial try was correct though... let me try to reason out what I would do for n < N ( chris also mentioned this in an earlier post ).
Hmm for some ##n < N## we can see that ##a_n > L + 1## so that ##L + 1## is not an upper bound so I would define :
I still don't see what's wrong with what I mentioned prior though.
max of ##a_n## for n<N is well defined regardless of whether the series even converges or not. You are taking the max of a FINITE number of terms. That's why it's well defined. max ##a_n## over all n is not. Until you say why it is. Your latest attempt makes that clear.
Ahh yes I understand your concern now. So I can't just use the max over what may potentially be an infinite number of terms as... that's simply broken.
EDIT : Cleaned up the proof in post #5, should be good now.
