Prove f(x) = sin(x^2) isn't periodic
  • Thread starter Thread starter Korisnik
    Periodic
The function f(x) = sin(x^2) is proven to be non-periodic through a series of logical deductions and mathematical constraints. The discussion highlights that if f were periodic, there would exist a constant T such that f(x + T) = f(x) for all x. Various values of x, including 0, √(π/2), and √(π), are analyzed to demonstrate that no consistent period T can satisfy the periodicity condition, ultimately leading to contradictions. The final conclusion is that f(x) = sin(x^2) does not possess a period.
  • Understanding of periodic functions and their definitions
  • Familiarity with trigonometric identities, particularly sin(a + b)
  • Knowledge of complex numbers and Euler's formula for sine
  • Basic algebra and manipulation of equations involving square roots
  • Study the properties of periodic functions in depth
  • Learn about trigonometric identities, especially sin(a + b) and their applications
  • Explore Euler's formula and its implications in trigonometric proofs
  • Investigate other non-periodic functions and their proofs of non-periodicity
Mathematicians, students studying advanced calculus, and anyone interested in the properties of trigonometric functions and periodicity proofs.
Korisnik
Member warned about posting homework questions w/o the template
Prove f(x) = sin(x^2) isn't periodic.
f is periodic if f(x + t) = f(x) for all x in f's domain.
I know about 1 way of proving it by derivative and boundedness but is this another way?
If f is periodic then
sin(x^2) = sin((x + t)^2)
Finding t:
(I don't know the proper way of doing this, maybe I ought to add + 2kpi)
x^2=x^2 +2xt + t^2
(I could square root it but it's the same)
t(t + 2x) = 0
t1 = 0 or t2 = -2x
t > 0 so t1 isn't.
t(x) = -2x, but t can't be dependent on x, as it needs to be constant, so t2 isn't a solutio . So I have proved the hipothesis.
As you said, your function is periodic iff there is ##T>0## such that ##f(x+T) = f(x)## for all real ##x##.
Assume ##f## is periodic. If you set ##x = 0##, what constraint does it impose on ##T## ? Now if ##x = \sqrt{\frac{\pi}{2}} ##, does your function conserve its periodicity with the T you just found ?
Hi Korisnik:
Unfortunately your proof is flawed.
sin(x^2) = sin((x + t)^2) does not imply that x^2 = (x + t)^2.
I have not found a proof, but I have two suggestions that you might try. However, I am not sure either will be helpful.
1. Use the formula for sin(a+b).
2. Use the formula expressing sin(a) in terms of eia and e-ia.
ADDED
My apologies. I haven't done proofs for many decades. Geoffrey has the suggested the right approach.
Regards,
Buzz
Alright, so ##T = \sqrt{k\pi}, k\in\mathbb{Z}##, as ##T>0##. Now ##x = \sqrt{\frac{\pi}{2}}## so ##f\left(\sqrt{\frac{\pi}{2}}\right) = 1## and ##f\left(\sqrt{\frac{\pi}{2}} + \sqrt{k\pi}\right) = \sin\left(\frac{\pi}{2} + k\pi +2\pi\sqrt{\frac{k}{2}}\right)## which will equal ##1## iff ##\frac{\pi}{2} + k\pi +2\pi\sqrt{\frac{k}{2}} = \frac{\pi}{2}+2k\pi ##. The solutions are ##0## and ##2##. If ##k = 0## ## T = 0##. For ##k = 2## ##T = \sqrt{2\pi}##. Now ##f\left(\sqrt{\frac{\pi}{2}}\right) = 1 = f\left(\sqrt{\frac{\pi}{2}} + \sqrt{2\pi}\right)## So the function is periodic?
I checked for ##x = \sqrt{\frac{\pi}{4}}## and it didn't work, so I guess it isn't periodic then. Is this now an okay proof or still no?
Hi Korisnik:
Yes, you have a proof now. But you may want to restructure it a little for clarity.
Step 1 assumes x=0. From this you find all the possible values of T that could possible be the period: T=√kπ, k any integer but 0.
Step 2 assumes x = √π/2. This reduces the possible periods to +/- √2π.
Step 3 assumes x = √π/4. This shows that neither t = +√2π nor t=-√2π are a period.
Regards,
Buzz
If ## x = 0 ##, you want to solve ## \sin (T^2) = 0 ## and ## T > 0 ##. Therefore ##T^2 \in \{ k\pi,\ k\in\mathbb{N}-\{0\} \}##. So there is an integer ## k \ge 1 ## such that ##T = \sqrt{k\pi}##.
Now if ##x = \sqrt{\frac{\pi}{2}}## and ##f## is periodic, you must have ##1=f(x) = f(x+T) = (-1)^k \cos(\sqrt{2k}\pi ) ##. Now you see that ##\sqrt{2k}## is odd when ##k## is odd and even when ##k## is even.
What can you say depending on the parity of ##k## ?
Essentially, this boils down to the fact that squaring is not linear.
Assume a period exists. Call it T.
Then sin((kT)^2) = 0. Great. So T^2 is a period of the sine function.
For any x, sin((x+kT)^2) = sin(x^2).
But, sin((x+kT)^2) = sin(x^2 + 2kTx +(kT)^2 ). Since T^2 is a period of the sine function, you can say that this is also equal to sin(x^2 + 2kTx).
I am pretty sure it doesn't take too many steps to show that 2kTx can't be a period of sin(x) since it is a function of x.
Hi Korisnik:
I apologize again. At my age I have become too careless to do proofs, so I will stay out of this thread after this,
Since my quotes of equations get messed up, I have reproduced below an equation from your post #4:
π/2 + kπ +2π√(k/2) = π/2 + 2kπ​
The error you made (which I failed to catch before) is assuming that the k variable on the left hand side is the same as the k variable on the right hand side. These two k's need not be the same value. Therefore your conclusion that k must be 0 or 2 is wrong.
Regards,
Buzz
Thanks for catching that.
I'm not sure what you mean by that, as decimal numbers (possibly square root of 2k) don't have parity. The obvious is that the sign changes depending on k.
Right, the sign changes and ##\sqrt{2k}## must be a positive integer of the same parity than ##k##.
Show it can't be odd. This will give you another constraint on the period, assuming it does exist.
Finally, try the case ##x=\sqrt{\pi}##, and you will get an absurd result which will prove that the hypothesis of periodicity is false.
2k = 4t^2, t \in Z, so k is even.
2k = 4t^2 + 4t + 1, so now 2 times k is an odd number, which it can't be, as k is integer: 2k = 2(2t^2 + 2t) + 1 = 2m + 1 (t and m aren't specified, but are integers). And we know that odd squared gives odd, and even squared gives even, not odd, so k can't be odd.
I get this result (plugging in sqrt(k*pi) for T and sqrt(pi) for x):
1 + k + 2*sqrt(k) = m, m is > 0 integer. I'm not sure what you mean by absurd result. How does this yield a solution?
Ok, so ## k = 2 t^2##. Then the period has an additional constraint : ##T = \sqrt{k\pi} = \sqrt{2\pi} t ##.
Now try ##T## with ##x = \sqrt{\pi}##, with the same kind of reasoning you should be able to conclude.
Right, I get sqrt(2)*2t + 2t^2 + 1 = m, m is integer. Can't be. Thanks. :)
  • · Replies 105 ·
  • · Replies 23 ·
