Prove P(n): "Proof by Induction for (1+h)n\geq1+nh+\frac{n(n+1)}{2}h2
  • Thread starter Thread starter major_maths
    Induction Proof
The problem involves proving the inequality (1+h)^n ≥ 1 + nh + (n(n+1)/2)h^2 for any positive h and integer n ≥ 0, using mathematical induction.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the base case and the inductive step, with one participant attempting to relate the expression for P(K+1) to P(K). Others are questioning the terms used in their inductive hypothesis, particularly the difference between k(k-1) and k(k+1).
There is ongoing exploration of the inductive hypothesis and its implications. Some participants are providing guidance on how to manipulate the expressions, while others are clarifying their understanding of the terms involved in the proof.
Participants note discrepancies in their notes regarding the terms used in the inductive hypothesis, leading to confusion about the correct formulation. There is also a reference to specific values (e.g., n=2) to illustrate the point being discussed.
major_maths
Prove that for any positive h and any integer n[itex]\geq[/itex]0, (1+h)n[itex]\geq[/itex]1+nh+[itex]\frac{n(n+1)}{2}[/itex]h2.
None.
I proved that P(0) is true (1[itex]\geq[/itex]1). The rest of the proof goes as follows:
Assume K[itex]\in[/itex]Z (the set of integers) and P(K) is true.
Then (1+h)K[itex]\geq[/itex]1+Kh+[itex]\frac{K(K-1)}{2}[/itex]h2.
Then (1+h)(K+1) = (1+h)K+(1+h)1...
I can't figure out how to relate that part to the final part of P(K+1), which is 1+(K+1)h+[itex]\frac{(K+1)(K+1-1)}{2}[/itex]h2.
You have that (1+h)K+1=(1+h)K(1+h) = P(K)(1+h), so see where that goes.
I'm working on the same problem, to show P(k+1) I set it up the same way
but then we can use our inductive hypothesis
(1+x)^(k+1) >= (1+kx+(1/2)*k(k-1)*x^2)(1+x)
My question is, I've wrestled with the algebra for a little while now and for some reason in my notes i had P(K) set to:
1+kx+(1/2)*k(k+1)*x^2
(where the 1 in k(k+1) is positive instead of negative) I think my professor did the problem with k+1 instead of k-1. But i thought from the inductive hypothesis the term is k(k-1) NOT k(k+1) because k+1 is what we get from P(k+1) that is what we get from the substitution?
I know there will be left over terms but i keep getting k(k-1)/2 instead of k(k+1)/2.
I believe you are correct. It has to be n(n-1) instead of n(n+1).
This is seen by picking n=2, then
[tex](1+h)^2=1+2h+h^2[/tex]
and not
[tex](1+h)^2=1+2h+3h^2[/tex]
  • · Replies 23 ·
