Prove: Sum of angles > 180 in curved space
In positively curved spaces, such as a sphere, the sum of the angles of a triangle exceeds 180 degrees, specifically expressed as v1 + v2 + v3 = π + A/R², where A is the area and R is the radius of the sphere. To prove this, one can utilize spherical trigonometry, particularly the relationship between side lengths and angles. By analyzing a triangle with one vertex at the north pole and the other two on the equator, it becomes evident that the angles at the equator are right angles, leading to an angle sum of 180 + θ, where θ is the angle at the north pole. The area of the triangle can be calculated as A = θR², confirming the relationship between angle sum and area. This demonstrates that the sum of angles in a spherical triangle indeed exceeds 180 degrees.
Niles
[SOLVED] Prove: Sum of angles > 180 in curved space
If I have a positively curved space (i.e. a sphere) and I draw a triangle on it, the sum of the angles of the triangle exceed \pi, more precisely,
v1 + v2 + v3 = pi + A/R^2
where v1, v2 and v3 are the angles of the triangle, A is the area of the triangle and R is the radius of the sphere.
This is what I have to prove.
Ok, first I setup the "environment". I will look at a triangle with equal long sides with one corner at the north-pole. What would be the next step from here?
We are told to verify the angle-relations using a triangle with equally long sides and the other two angles lying on the equator; sorry, I should have written that in post #0.
I really appreciate the links, and I know the identity:
<br /> ds^2\,=\,dr^2\,+\,R^2 \sin ^2 (r/R)d\theta ^2,<br />
where R is the radius of the sphere and (r, theta) is a point on the sphere (r is the distance from the northpole).
If I stand at the vertex situated at the northpole, then I can write the above identity as
<br /> ds^2\,=\,R^2 \sin ^2 (r/R)d\theta ^2,<br />
where r = ½*Pi*R, since the side is one quarter of the circumference. Then I integrate, and I get that one side equals 2*Pi*R^2*sin(Pi/2). I have three of those, and since they are equally long, I can multiply by 3 to get the total circumference of my triangle.
The law of sine apparently works as usual (from http://en.wikipedia.org/wiki/Spherical_trigonometry) on the triangle, so I get that the angles must equal each other.
How am I doing so far?
I don't know why, but I'm not able to edit my last post. There is an error: The side equals Pi*R/2.
Okay, so you don't need to prove the statement, just verify it in that simple case.
Okay, take two points on the equator and the third point as the north pole. It is obvious that the two angles on the equator will be right angles so the angle sum is 180+ \theta where \theta is the angle at the north pole. It's easy to calculate that the triangle takes up \theta/(4\pi) of the entire sphere (\theta is measured in radians). Since the surface area of the entire sphere is 4\pi R^2, the area of the triangle is A= \theta R^2. Solve that for \theta and you are done.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 29 ·
