Prove that a limit does not exist
  • Thread starter Thread starter Anro
    Limit
The limit limx→2 (1/(x – 2)) does not exist due to the behavior of the function as x approaches 2 from both sides. By using the sequential criterion for nonexistence, two sequences converging to 2 were analyzed: {x_n} approaching from above and {y_n} approaching from below. The limit of f(x_n) approaches +∞, while the limit of f(y_n) approaches -∞, demonstrating that the limits are not equal. Therefore, since the limits diverge, it confirms that the limit does not exist. The conclusion is that limx→2 (1/(x – 2)) is undefined.
Anro
Prove that limx→2 (1/(x – 2)) does not exist.
2. The attempt at a solution
My approach to this problem is to use the sequential criterion for nonexistence, that is, if {x_n} and {y_n} both converge to a (2 in this case), but limx→a f(x_n) is not equal to limx→a f(y_n), then limx→a f(x) does not exist (a being 2 in this case).
I was able to find two sequences, {x_n} and {y_n}, both converging to 2 (I chose {x_n} = 1.5 + (1/n) and {y_n} = 2.5 – (1/n) as converging sequences). But when I try to plug these values in f(x_n) and f(y_n), I get (2 – n) or an integral multiple of it in the denominator which doesn’t help me when taking the limit for either f(x_n) or f(y_n) when n→2.
I also tried some other combinations but I seem to run into the same problem, division by zero when taking the limit for either f(x_n) or f(y_n), can you please tell me if I am missing something or if I am doing something wrong here? Thanks in advance for all your help.
You don't want n → 2. You need {xn} → 2 as n → ∞, and {yn} → 2 as n → ∞, while f(x_n) ≠ f(y_n) as n → ∞.
What you have done (n->infinity, x_n-> 2) is perfectly valid (I think Sammy S misunderstood what you were saying) but, since you get x_n-2 in the denominator, the denominator is going to 0 while the numerator is always 1. Of course, that does not exist- it goes to infinity.
(Note: saying lim_{x\to 2} f(x)= \infty is just another way of say the limit does not exist. "Infinity" is NOT a number so is not a limit.)
Or, try x_n= 2+ 1/n, y_n= 2- 1/n. As n goes to infinity, x_n goes to 2 "from above" and the limit is +infinity while y_n goes to 2 "from below" and the limit is -infinity.
it is possible to use the definition of the limit directly, here.
suppose that f DID have a limit at 2, call it L.
could this limit be 0? no, because if we choose, say ε = 1,
then anytime |x-2| < 1, |f(x)| = 1/|x-2| > 1, so we can't find a δ.
so if L exists, L ≠ 0. therefore |L| > 0, and we can use that as our ε.
but if 0 < |x-2| < 1/(2|L|),
then |1/(x-2) - L| ≥ 1/|x-2| - |L|...can you see how to finish?
no matter how small a δ we choose, there will be some x for which |x-2| < 1/(2|L|),
which means...?
Thanks for the answers everyone; here is what I have done so far:
Choose {x_n} = 2 + (1/n). Then limn→∞ (x_n) = 2.
Hence 1/((x_n) – 2) = n = f(x_n), and limn→∞ f(x_n) = limn→∞ n = ∞
Now choose {y_n} = 2 - (1/n). Then limn→∞ (y_n) = 2.
Hence 1/((y_n) – 2) = (-n) = f(y_n), and limn→∞ f(y_n) = limn→∞ (-n) = -∞
Since limn→∞ f(x_n) does not equal limn→∞ f(y_n), then limn→∞ f(x) does not exist.
Thus limx→2 (1/(x – 2)) does not exist.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
