Convergence of the Sequence An = √(2^n + 3^n)
  • Thread starter Thread starter atthebeach
    Sequence
The sequence an = √(2^n + 3^n) is analyzed for convergence, with a focus on proving it converges to 3. By factoring 3^n out of the radical, the expression simplifies to 3 * nth root of ((2/3)^n + 1). As n approaches infinity, the term (2/3)^n approaches 0, leading to the conclusion that the limit of the sequence is indeed 3. While an epsilon proof was considered, it is determined that a simpler argument suffices for this problem. The discussion emphasizes the importance of algebraic manipulation in understanding the convergence of the sequence.
atthebeach
If an = \sqrt[n]{2^n+3^n} does the sequence converge? Prove your assertion.
I have no idea where to start with this problem. It does have something to with \exists N such that n>N \Rightarrow |an - a| < ϵ for all ϵ>0
Can yall help me? It would be greatly appreciated.
Start by factoring 3^n out of the radical. Use some algebra.
Can you get any results. Is the sequence bounded? Is it monotonically increasing or decreasing? etc?
It is monotone decreasing. Looking at a graph I can deduce that it converges to 3. but I really struggle with the proof...and the algebra sadly.
How would I factor 3^n out of the radical??
Algebra. Factor 2^n+3^n=(3^n)*(something). What's the (something)? Find out by doing algebra.
Lack of algebra skills is bad news. Let me put the same problem more simply. Suppose the expression were a+b=a*x. What's x?
I think I figured it out. would it be 3 * nth root of ((3/2)^n+1)?
Close. Can you show how you got there? Why did you get (3/2)^n instead of (2/3)^n?
oops i meant to write that. so from here do i need to find the N?
Not necessarily. I don't think this is probably an epsilon type of proof, unless the problem says it is. You just need an argument that says it's true. lim n->inf (2/3)^n=0, right?
yes. but then i have the 1 under the radical and i know that the infinith root of 1 would be 1. but...i cannot split up the terms under the radical
So? What would that make the limit? What's nth root of 1?
OHHH the limit would be three thank you so much. I think maybe i was supposed to do an epsilon proof but this should be sufficient
Very welcome. I think an epsilon type proof would be more challenging than the problem actually calls for.
  • · Replies 17 ·
  • · Replies 34 ·
