Undergrad Prove that V is the internal direct sum of two subspaces
In the context of vector spaces, V is defined as the internal direct sum of two subspaces U1 and U2 if U1 + U2 = V and U1 ∩ U2 = {0V}. This means every vector in V can be uniquely expressed as a sum of vectors from U1 and U2. The uniqueness of representation is crucial; if two subspaces overlap, a vector can be represented in multiple ways, indicating non-uniqueness. The discussion emphasizes that while U1 and U2 may overlap, they are not identical, and their intersection must be a vector space of dimension at least 1.
  • Understanding of vector spaces and subspaces
  • Familiarity with the concept of direct sums in linear algebra
  • Knowledge of vector space intersection properties
  • Basic comprehension of vector space dimensions
  • Study the properties of vector space intersections and their dimensions
  • Explore the implications of direct sums in linear algebra
  • Learn about unique representations of vectors in vector spaces
  • Investigate examples of vector spaces with non-trivial intersections
Students and professionals in mathematics, particularly those studying linear algebra, vector spaces, and their properties, will benefit from this discussion.
Austin Chang
Let V be a vector space. If U 1 and U2 are subspaces of V s.t. U1+U2 = V and U1 and U1∩U2 = {0V}, then we say that V is the internal direct sum of U1 and U2. In this case we write V = U1⊕U2. Show that V is internal direct sum of U1 and U2if and only if every vector in V may be written uniquely in the form v1+v2 with v1∈U1 and v2∈ U2.
What does it mean to be unique? Does it matter if it is unique?
It means that for any vector ##u\in V##, if ##w_1+w_2=u=v_1+v_2##, for ##w_1,v_1\in U_1## and ##w_2,v_2\in U_2##, then ##v_1=w_1## and ##v_2=w_2##.
Yes, the uniqueness matters. If the two subspaces overlap, there is more than one way of writing a vector in ##V## as a sum of two vectors one from each subspace. And vice versa, if the representation as a sum is not unique, the two subspaces must overlap.
So for your example if it was not unique U2 = U1 and you can write w1 in U2 and w2 in U1? therefore w2+w1 is not unique anymore because the same things came from different subspaces?
Perhaps an example of non-uniqueness will make this clear. You can represent 12 as the product of two factors ##12 = x_1 x_2## but the two factors are not unique since they and be chosen to have various different values - e.g. (12)(1), (4)(3), (2)(6) etc.
As whether uniqueness matters - that's a subjective question. Uniqueness is often a convenient property to have. For example, the rigorous approach to defining "a" zero z_1 in arithmetic would be to define it by the property that for all numbers x, z1 + x = x. It is convenient that there is a unique number, denoted by "0", that has this property. If there were several unequal zeroes, arithmetic would be more complicated.
Likes Austin Chang
No, that would be going too far. U2 and U1 will overlap nontrivially, but that doesn't mean they are identical. All it means that their intersection is a vector space of dimension at least 1.
Thanks! That was a good example.
What do you mean by at least a vector space of dimension 1? I don't think I've gotten that far to understand it completely. Could you elaborate?
Austin Chang said:
What do you mean by a vector space of dimension at least 1?
A vector space that is not just ##\{0_V\}##.
  • · Replies 59 ·
9K
