Prove $(xyz)^8=1$ for $x,y,z \in R$
  • Context: MHB
  • Thread starter Thread starter Albert1
The discussion revolves around the mathematical assertion that if \(x, y, z \in \mathbb{R}\) satisfy the equation \(x + \frac{1}{y} = y + \frac{1}{z} = z + \frac{1}{x}\), then it can be proven that \((xyz)^8 = 1\). Participants explore the validity of this assertion, the implications of certain conditions, and the aesthetics of the problem formulation.
  • Post 1 presents the initial assertion to prove \((xyz)^8 = 1\) under the given condition.
  • Post 2 challenges the assertion by providing a counterexample with \(x = y = z = 2\), indicating that the conclusion does not hold.
  • Post 3 reiterates the counterexample and suggests that the case where \(x = y = z\) should be excluded from consideration.
  • Post 5 provides a derivation leading to \(x^2y^2z^2 = 1\) under the assumption \(x \neq y\), concluding that this implies \((xyz)^8 = 1\).
  • Post 6 repeats the derivation and expresses skepticism about the conclusion being odd for the theorem.
  • Post 8 argues that the initial statement remains valid even if \(x = y = z\), but it does not lead to the desired result.
  • Post 10 discusses the implications of \(x^2y^2z^2 = 1\) leading to \(xyz = \pm 1\) and thus \((xyz)^8 = 1\), while also questioning the necessity of proving the higher power.
  • Post 12 raises two statements regarding the equivalence of powers, noting that they hold true in the real number system but may differ in the complex number system.
  • Post 14 emphasizes that while the mathematical assertion is valid, the aesthetics of the problem could be improved by posing a simpler challenge involving \((xyz)^2 = 1\).
  • Post 15 agrees with the aesthetic perspective, suggesting that a problem framed with lower powers may be more appealing and easier for students.
Participants express disagreement regarding the validity of the original assertion and the implications of the conditions set forth. While some participants support the conclusion that \((xyz)^8 = 1\) can be derived, others challenge its necessity and propose that a simpler formulation would be more appropriate. The discussion remains unresolved regarding the optimal presentation of the problem.
Some participants note that the conclusion \((xyz)^8 = 1\) follows from \(x^2y^2z^2 = 1\), but question whether it is the most relevant or aesthetically pleasing result to pursue. The discussion also highlights the importance of the conditions under which the assertions are made, particularly the exclusions of cases where \(x = y = z\).
Albert1
$x,y,z \,\, \in R$
$x+\dfrac{1}{y}=y+\dfrac{1}{z}=z+\dfrac{1}{x}$
$prove :x^8y^8z^8=1$
Mathematics news on Phys.org
Something doesn't look right. Consider $x = y= z = 2$. Then clearly
$x + \dfrac{1}{y} = y + \dfrac{1}{z} = z + \dfrac{1}{z} = 2 \dfrac{1}{2}$
yet $x^8y^8z^8 \ne 1$.
if x=y=z then this problem doesn't make any sense.
of course here x=y=z will be excluded
And why does $x=y=z$ not make sense?
Albert said:
$x,y,z \,\, \in R$
$x-y=\dfrac {1}{z}-\dfrac {1}{y}=\dfrac {y-z}{yz}$
$\therefore yz=\dfrac {y-z}{x-y} ,( here \,\, x\neq y)------(1)$
$\text {likewise :}$
$ xy=\dfrac {x-y}{z-x} ,( here \,\, z\neq x)------(2)$
$ zx=\dfrac {z-x}{y-z} ,( here \,\, y\neq z)------(3)$
$(1)\times (2)\times (3) :x^2y^2z^2=1$
$\therefore x^8y^8z^8=1$
$x^{8}y^{8}z^{8}=1$ seems a very odd conclusion for such a theorem. Normally, a conclusion like that would be for the purpose of illustrating why the equality doesn't work for a lower power, rather like why $x^{2}+y^{2}$ does not factor over the reals, but $x^{4}+y^{4}$ does.
$ \text{since} \,\, x,y,z\in R$
$x^2y^2z^2=1$$\text{implies}\,\,\, xyz= \pm 1$
I understand that
leads to
Albert said:
$\therefore yz=\dfrac {y-z}{x-y} $
only if $x \ne y$ but the first statement is still true if $x=y=z$ so $x=y=z$ makes sense, just not to give your result.
Jester said:
I understand that leads to only if $x \ne y$ but the first statement is still true if $x=y=z$ so $x=y=z$ makes sense, just not to give your result.
yes the original statement is true (like 2=2=2 ,or 3=3=3)
but the statement is otiose,and as you said will not give to my result
I understand that. My comment was intended to say that, as mathematical aesthetics go, since $x^{2}y^{2}z^{2}=1$ is a stronger conclusion than $x^{8}y^{8}z^{8}=1$, you would generally want to stop at the smaller power. What I'm saying is that I think the problem should be to prove $(xyz)^{2}=1$, not $(xyz)^{8}=1$.
$ginen \,\, x,y,z \in R$
statement (1)
$if \,\, (xyz)^{2}=1 \,\, then \,\, (xyz)^{2k}=1( k\in N)$
statement (2)
$if \,\, (xyz)^{2k}=1 \,\, then \,\, (xyz)^{2}=1( k\in N)$
these two statements which one is true ?
statement (1)
statement (2)
thes two statements which one is true ?
In the real number system, they would be exactly equivalent. However, if you allow complex numbers into the picture, the first is true and the second is not. Counterexample: $(xyz)^{4}=1$ but $(xyz)^{2}=-1$.
so as you said In the real number system, they would be exactly equivalent (statement
(1) and statement(2) )
$x,y,z \in R \,\, and \,\, k\in N$
$ if \,\, (xyz)^2=1 \,\, then \,\, (xyz)^{2k}=1$ ,---- statement(1)
$\therefore if \,\, (xyz)^2=1 \,\, then \,\, (xyz)^8=1$
(even we allow complex numbers into the picture, the first is true,but here we only take real
numbers into consideration)
now any objection ?
now any objection ?
I don't think I'm communicating very well here. It's not that I object to the truthfulness of this challenge problem. I would agree that if $x+1/y=y+1/z=z+1/x$, and if $x\not=y$ and $y\not=z$ and $z\not=x$, then $(xyz)^{8}=1$. There's no need even to insist on $x,y,z\in \mathbb{R}$ - they could be complex. You proved this in post 5. So I'm not objecting to whether your challenge problem is correct or not.
I object to the aesthetics of this challenge problem. In post 5, you proved something stronger than $(xyz)^{8}=1$, namely, $(xyz)^{2}=1$. Therefore, I would argue that posing the following challenge problem is more aesthetically pleasing:
Given that $x+1/y=y+1/z=z+1/x$, and $x\not=y, y\not=z, z\not=x$, prove that $(xyz)^{2}=1$.
So, to reiterate, what I'm saying here is like saying that one work of art is more beautiful than another. I'm not saying that either one of them fails to be a work of art!
Ok! taking aesthetics into consideration I agree with you the following work is more beautiful
it may sell better price in an auction market (besides it is easier for students at first glance)
