Proving Closure and Identity for U(n)
  • Thread starter Kaguro
    Group
16 replies · 6K views · last reply
Kaguro
If U(n) denotes the set of all positive integers less than n which are coprime with n. Then prove that U(n) is a group under multiplication modulo n.
I don't know..
Closure
Let a,b ∈U(n).
a has no common factor with n (other than 1)
b has no common factor with n(,,)
So,
If ab < n, then ab doesn't have any common factors with n.
If ab>n, then for some p,ab-pn < n.
Since ab doesn't have any common factor with n, ab-pn can't either.
(ab≠ n, because neither a nor b can have any common factors with n)
So, ab ∈ U(n)
Closure is verified.
Associativity:
Multiplication modulo n is associative( I'm not even going to think about proving that)
Identity: 1 is the identity.
Inverse:
This is where I got obliterated...
Let a ∈ U(n).
We need an x such that:
Consider ax= pn+1 for some p.
I need to prove that
1)x= (pn+1)/a is an integer
2)It also doesn't have anything common with n.
I have zero idea how do I prove something like this... Please give me some direction.
Does it have anything to do with the Euclid division algorithm?
Yes, it has. We can write all these numbers as ##[0],[1],[2],\ldots,[n-1]##. They are the remainders of a division by ##n##. Since we are looking for a multiplicative group, we do not need the zero ##[0]##. Now try to understand what ##[a]\cdot [ b ]## means! Here Euclid comes into play: Say we have two integers ##p,q## and divide them by ##n##. Then we get for instance ##p=s\cdot n +a ## and ##q=t\cdot n +b##. So what is ##[a]\cdot [ b ]## then?
If you understood this, then the question about the group axioms have to be answered. Hint: It are the inverse elements which cause the trouble here. Hence ask yourself the question: What has to happen, such that a certain ##[c]## is not invertible?
fresh_42 said:
Say we have two integers p and qp,q and divide them by n n. Then we get for instance p=sn+a,,p=s⋅n+a and q=t⋅n+bq=tn+b. So what is [a]⋅ ab then?
Just ab. Absolutely nothing special about it.
Given n, and fixing an element a, I am to find integer x for
ax = yn+1
For every real x, there is a y (just a straight line). For every integer x, also some real y is there.
For some integers x, y also happens to be an integer. Actually there are an infinite number of them.
For example consider U(7). And take element 5.
5*3=15 = 2*7+1. So for x=3,y=2
But also for 5*10=50=49+1=7*7+1. For x=10,y=7..
I need only x<n.
Such an integer pair (x,y) will exist seems like a world-shattering claim to me...
fresh_42 said:
What about ##U(12)##? What is ##3^{-1}## in this case?
U(12)={1,5,7,11}
It doesn't have 3. So 3 inverse doesn't make any sense.
3x=12p+1 for no integers x and p.
Yes. That's the point why only coprime elements are considered. Coprime numbers ##a,n## means, that we can write ##1=pa+qn## with some integers ##p,q## according to Bezout's lemma. This equation is equivalent to the possibility to find an inverse for ##a## modulo ##n##, namely ##p##.
It is what this exercise was made for. Associativity is inherited from the integers, and the coset of ##1## is the natural neutral element.
I have understood what Bezout's Lemma is trying to say. Given integers a and b, the GCD of them lies in their integer span.
But this claim seems highly non-trivial to me. I will have to read a simple proof of it to help me understand.
Okay, so I understand the proof of Bezout's Lemma.
Basically, consider two integers a and b. Consider the set of all positive integer linear combinations of them. Let d be the smallest such element. Prove that this thing has to divide both a and b. Then prove that given any common divisor c of a and b, c has to divide d. So d is the HCF of a and b.
Source : https://www.expii.com/t/bezouts-identity-on-linear-combinations-3397
Now considering coprime a and b, d=1. So we can always write:
a=my+1
Now, let's prove the existence of inverse:
Let a∈U(n) ⇒ HCF(a,n)=1
Let x∈U(n) ⇒ HCF(x,n)=1
So, HCF(ax,n) = 1
So, we can always write: ax = pn + 1 for some integer p.
This, under multiplication mod n, will come out to be 1. So one particular x is the inverse of a. There always exists such an x.
Number Theory is powerful!
All the formulations with Bezout's lemma, the definition of ##U(n)##, and Euclid's algorithm, which allows division such that ##u=q\cdot n + 1## can be written for ##u\in U(n),## are closely related:
If you consider the function ##\pi : \mathbb{Z} \longrightarrow \{[0],[1],[2],\ldots,[ n ]\}=:\mathbb{Z}_n## which maps any integer onto its remainder from division by ##n##, then you can observe that ##\pi(a+b)=\pi(a)+\pi(b)## and ##\pi(a\cdot b)=\pi(a)\cdot\pi(b)##.
The elements of ##\mathbb{Z}_n\supseteq U(n)=\{[d]\,|\,gcd(d,n)=1\}## are called units of ##\mathbb{Z}_n## which is why they are abbreviated by a ##U##. For those units we have an equation ##[a]\cdot[ b ]=[1]## per definition. We get from ##[a]=\pi(a),[ b ]=\pi(b),[1]=\pi(1)## with the above formulas, that ##\pi(a\cdot b- 1)=[0]##, which means ##n\,|\,(a\cdot b -1)## which means ##1=a\cdot b + q\cdot n## for some integer ##q##.
The sophisticated answer to the exercise is either
##\pi## is a ring homomorphism, so ##U(n)=\pi(\{1\})## is a multiplicative group as homomorphic image of the group ##\{1\}.##
or
Unities in a ring are always a multiplicative group.
The purpose of this exercise was to shine some light on these different points of view along an easy to compute example. I think you should prove the two formulas (##\pi(a+b)=\pi(a)+\pi(b)## and ##\pi(a\cdot b)=\pi(a)\cdot\pi(b) \Longrightarrow \pi## is a ring homomorphism) above as an exercise. Not so much for the formulas themselves or to learn what a ring homomorphism is, but to practice proof writing!
Wait!
I'm just a third year undergraduate physics student studying group theory for the fist time. I have just read the first two chapters of "Contemporary abstract algebra by Joseph Gallian". I have to go slowly.
Let me ask several questions:
Why do you keep writing the numbers with square brackets?
Zn is {0,1,2,...n-1} under addition modulo n. It contains 0. U(n) doesn't. So why did you say Zn is subset of U(n)?
Kaguro said:
Wait!
I use square brackets to indicate that they are not numbers, but entire sets. Let's take ##n=6##. Then ##[0]=\{\ldots,-12,-6,0,6,12,18,\ldots\}## or ##[2]=\{\ldots,-16,-10,-4,2,8,14,\ldots\}##. They are equivalence classes: all possible remainders which are considered to be the same: ##-10=(-2)\cdot 6 + 2 = (-1)\cdot 6 + (-4) = 0\cdot 6 - 10= (-3)\cdot 6 + 8=\ldots ## The numbers between ##0## and ##n-1## are only the most comfortable representatives of these sets, but ##-10 \equiv 2 \mod 6## so it is only convenience which makes us choose ##2## and not ##-10##.
As I already mentioned. You should prove ##[a+ b ]=\pi(a+b)=\pi(a) + \pi( b) = [a] + [ b ]## and ##[a\cdot b ]=\pi(a\cdot b)=\pi(a) \cdot \pi( b) = [a] \cdot [ b ]## to practice proof writing. It will also show you why this example is an important one. And a closer look will show you, that while communicating here we are using the case ##n=2## all the time!
Okay! Don't mind if I take some time.
Are you talking about the binary number system?
Yes. And for ##n=5## we get ##U(5)\cong\{i,-1,-i,1\}.##
[a] ≡ π(a) = a-pn such that 0 ≤ a-pn <n
[b ] ≡ π(b) = b-qn such that 0 ≤ b-qn <n
So, [a]+[b ] = a+b - (p+q)n
If a+b - (p+q)n < n then,
[a]+[b ] = [a+b]
If a+b - (p+q)n ≥ n, then a+b - (p+q+1)n < n and this is equal to [a+b]
Hence, [a]+[b ] = [a+b]Similarly,
[a][b ] = (a-pn)(b-qn) = ab-aqn - bpn + pqn^2
If this is less than n, then it can be written as:
[a][b ] = (a-pn)(b-qn) = ab -(aq+ bp + pqn)n = [ab]
If this is greater than or equals to n, then ab -(aq+ bp + pqn+1)n <n and this is equal to [ab]
Hence [a][b ] = [ab]How about these?
P.S.: I spent some time thinking why I couldn't write square bracket b and all the text was somehow bold... Then it hit me. :smile:
Kaguro said:
How about these?
Except for your emphasis on numbers between ##0## and ##n## it is fine. We do not need those numbers. We have entire sets as elements. So if ##\pi(a)=[a]## then we can think of ##[a]=a+n\cdot \mathbb{Z}##. Now every integers ##a,b## can be written as ##a=pn+r## and ##b=qn+s##. Hence ##ab=rs+c\cdot n## for some ##p,q,c##. This means ##(a+n\mathbb{Z})\cdot(b+n\mathbb{Z})=r\cdot s +n\mathbb{Z} \Longleftrightarrow \pi(a)\cdot \pi(b) = \pi(ab)##. No considerations about the range of ##r,s## are necessary.
Yes, I regularly run into the same trap. And by the way, ##[ i ]## has a similar effect.
Oh okay! I understand.
Thank you very much for helping me.
I aspire to grow mathematically mature one day.
