Proving Continuity of a Function Using Epsilon-Delta Definition
  • Thread starter Thread starter Polter19
    General Proof
4 replies · 4K views
Polter19
Hey guys, I've been given the following [itex]\epsilon - \delta[/itex] proof question. The trouble I'm having is I'm not 100% sure what it is actually asking for, and how to go about it. The more common proofs involving two variable functions and a given limit are easy enough to do, but I'm stuck on this one.
Suppose [itex]f: \left( \mathbb R ^2 , \| . \|_2 \right) \rightarrow \left( \mathbb R , | .| \right)[/itex] is continuous at [itex]\left(a,b \right) \in \mathbb R^2[/itex]. Prove using the [itex]\epsilon - \delta[/itex] definition only, that if we define the function
[itex]f_b : \left( \mathbb R,|.| \right) \rightarrow \left( \mathbb R,|.| \right)[/itex] s.t. [itex]f_b \left(x \right) = f \left( x,b \right),[/itex]
then [itex]f_b[/itex] is continuous at [itex]x=a[/itex].
Well, considering I am not actually sure what the question is acting for I can't go very far. I was assuming you would set up the usual proof as,
Let [itex]\epsilon > 0[/itex]
if [itex]|(x,b) - (a,b)| < \delta[/itex]
then [itex]|f(x,b) - (a,b)| < \epsilon[/itex]
Possibly then, [itex]x - a < \delta[/itex]?
Any help would be appreciated, cheers.
Take [itex]\varepsilon >0[/itex] fixed.
You know that f is continuous at (a,b), thus you know that there exists a [itex]\delta>0[/itex] such that for all (x,y) it holds that
[tex]\|(x,y)-(a,b)\|_2<\delta~\Rightarrow~|f(x,y)-f(a,b)|<\varepsilon[/tex]
Now, what you must do is to show [itex]f_b[/itex] continuous at a. Thus you must find a [itex]\delta>0[/itex] such that for all x it holds that
[tex]|x-a|<\delta~\Rightarrow~|f(x,b)-f(a,b)|<\varepsilon[/tex]
Can you proceed now?
I am also interested in this question. I understand what is required for the proof, but I am just stuck as to how to manipulate:
|f(x,b) - f(a,b)|
into something that resembles δ??
We know that:
0 < ||(x,y) - (a,b) || < δ [itex]\Rightarrow[/itex] |f(x,y) - f(a,b)| < ε
as the limit is equal to the value of the function at (a,b) since it is continuous there, but how can we follow on from this to show that if y is restricted to equalling b, then:
0 < ||(x,b) - (a,b) || = ||x-a|| < δ [itex]\Rightarrow[/itex] |f(x,b) - f(a,b)| < ε
?? I'm really stuck and any help would be appreciated.
|f(x,b) - f(a,b)|
We know that:
How is ||(x, y)- (a, b)|| defined? (there are several equivalent definitions- which are you using?)
||(x,y) - (a,b)|| is a norm measuring the distance from (a,b) to (x,y), what do you mean how is it defined? Distance between points in R^2, euclidean norm.
