Proving dE/dT = F × V in special relativity
9 replies · 3K views · last reply
unam1292
I'm trying to show that
[tex]\frac{dE}{dT}[/tex]= F x V where F is force and V is velocity
Can someone please help me out?
F=[tex]\frac{dP}{dT}[/tex]=M x V x [tex]\gamma[/tex]
All of the other equations from special relativity (contraction, dilation, energy) are probably important as well.
Honestly, I have no idea where to start. Can someone please point me in the right direction. I'm a high school junior and I have very little experience with relativity. I understand that I should show some work, but I truly don't have any but I have been trying for a while.
Please help me get started!
You should know the formula for the relativistic energy E of an object. Try differentiating that with respect to time and see what you get.
The formulas for relativistic energy don't involve time (t) as far as I can tell.
I'm not sure how taking the derivative of that would help unless I'm
overlooking something.
It doesn't depend explicitly on time, but the energy depends on [itex]\gamma[/itex], which, in turn, depends on velocity, which does change with time.
gosh, now I'm even more stuck, thanks anyway.
so you meant that I should use [tex]\frac{x}{t}[/tex] instead of v?
well after doing that, and taking the derivative, I can see no way for it to manipulate in F x V.
No, I think that'll make it more complicated. Keep it in terms of just the velocity v.
Start with this first. You know that
[tex]\gamma = \frac{1}{\sqrt{1-(v/c)^2}}[/tex]
What do you get if you differentiate it with respect to time, remembering that v is a function of time?
ok, this is what I have
[tex]\frac{dE}{dt}[/tex]=[tex]mc^{2}\frac{-\gamma^{3}v}{c^{2}}\frac{dv}{dt}[/tex]= F x V
am I doing this correctly? when equate the equation above with F x V (where F = gamma*mass*acceleration*v)
i get that -[tex]\gamma^{3}=\gamma[/tex] so I get the feeling I messed up somewhere...
I really appreciate your help!
Hmm, not sure how you came up with that. Can you show more steps?
Sure,
So here's the derivative of gamma
[tex]\dot {\gamma} = \frac{d}{dt} \left( 1- \frac{v^2}{c^2} \right) ^{-1/2} = \left( \frac{-1}{2} \right) \left( \frac{-2v \dot {v} }{c^2} \right) \left( 1- \frac{v^2}{c^2} \right) ^{-3/2} = \gamma ^3 \left( \frac{v \dot {v}}{c^2} \right)[/tex]
hence
[tex]\frac{dE}{dt}=mc^{2}\frac{-\gamma^{3}v}{c^{2}}\frac{dv}{dt}[/tex]
because E = mc[tex]^{2}\gamma[/tex].
[tex]F\bulletV=m\gamma\frac{dv}{dt}v = \frac{dE}{dt}=mc^{2}\frac{\gamma^{3}v}{c^{2}}\frac{dv}{dt}[/tex]
and then I simplified this
You're getting there. You need to be a bit more careful when calculating F. You know that the momentum is given by [itex]p=\gamma mv[/itex]. When you differentiate it, you need to use the product rule.
