Proving ∮ ||F||² dF = -∫∫ 2F×dA using Stokes theorem
Gregg
Prove that
## \oint_{\partial S} ||\vec{F}||^2 d\vec{F} = -\int\int_S 2 \vec{F}\times d\vec{A} ##
Identities:
##\nabla \times (||\vec{F}||^2 \vec{k}) = 2\vec{F} \times \vec{k} ##
For ##\vec{k} ## constant i.e. ## \nabla \times \vec{k} = 0 ##
Stokes Theorem
##\oint_{\partial S} \vec{B} \cdot d\vec{x} = \int\int_S (\nabla \times \vec{B})\cdot d \vec{A} ##
So I need to use that identity ##\nabla \times (||\vec{F}||^2 \vec{k}) = 2\vec{F} \times \vec{k} ##
The problem is that Stokes theorem is in a different form. The constant vector here I think is the k=dA.
I really can't think of what to do
Well, [itex]\vec F[/itex] is the vector field, but I'm not sure what [itex]||\vec F||[/itex] represents in the original equation.
Assuming that there are no more mistakes in your first post, [itex]\vec k[/itex] represents the outward unit normal vector from the surface, S.
Maybe you should use Stokes' theorem for each component of the original vector-valued integral
[tex]\vec{I}= \oint ||\vec{F}||^2 d\vec{F}[/tex]
[tex]I_x = \oint (||\vec{F}||^2 \vec{e}_x) \cdot d\vec{F}[/tex]
etc. Now it's in the correct form.
I don't understand this?
[itex]\vec{e}_x[/itex] is the unit vector in x-direction. The lower integral is just the x-component of your full integral. You can calculate this by taking the dot product with [itex]\vec{e}_x[/itex].
