Proving H is a subgroup of G, given
  • Thread starter Thread starter hari!
    Subgroup
The problem involves proving that a set H, defined as the collection of elements in an abelian group G whose orders divide a fixed positive integer k, is a subgroup of G. The discussion revolves around the definitions and properties of groups and subgroups.
  • Conceptual clarification, Assumption checking, Problem interpretation
  • Participants discuss the necessary conditions for H to be a subgroup, including closure under the group operation and the inclusion of the identity element. There is confusion about the implications of the order of elements and how to demonstrate closure and the presence of inverses.
Some participants have provided guidance on how to approach the proof, particularly emphasizing the need to start from the properties of elements in H. There is an ongoing exploration of the implications of the order of elements and how it relates to the subgroup criteria.
There is a noted misunderstanding regarding the notation |a|, with one participant initially interpreting it as the absolute value rather than the order of the element. This has led to clarifications about the definitions involved in the problem.
hari!
Let G be an abelian group, k a fixed positive integer, and H = {a is an element of G; |a| divides k}. Prove that H is a subgroup of G.
Definition of groups, subgroups, and general knowledge of division algorithm.
I know that to prove H is a subgroup of G, I need to:
1) prove that it is closed (so if a and b are in H, ab is in H)
2) prove that if a is in H, then a-1 is in H as well.
I'm somewhat confused on how to proceed. To prove the first part, I suppose that ab is an element of H. Then we can write abn = k for some integer n. Because G is abelian, we can use associativity and commutativity to write (a)(bn) = k and (b)(an) = k. This clearly shows that a divides k and b divides k.
The problem is that I'm not sure if I went the wrong direction - meaning I supposed ab was in H, and proved a and b are in H.
I'm also at a loss on how to approach the second part. It's driving me mad because this is an "easy" problem and it's the one that's stumping me on this problem set.
You also need to prove
3) e is in H
Yes, you went in the wrong direction. You need to start from a,b in H. So you start from knowing that ak=e and bk=e. And you need to prove (ab)k=e.
Here you need to prove that if a in H, then a-1 is in H. So if ak=e, then (a-1)k=e.
I'm not sure I follow; the problem states that |a| divides k, not that k is the order of any element in the subgroup. So how do we know that ak = e for any a in H?
Since the order of any element a divides k, let the order of some element a be n. then, n times some integer, say, j, equals k. So, ak=anj=(an)j...see how this equals e?
I'm a little ashamed to say this, but I was reading |a| as absolute value of a, not order of a. This makes perfect sense then, thank you both for your help!
