Proving Lim x = -2, x^2+3x+7 = 5 | Epsilon Delta Proof Help"
The discussion revolves around proving the limit of the function x^2 + 3x + 7 as x approaches -2, specifically showing that it equals 5 using an epsilon-delta proof. Participants are exploring the application of quadratic functions in this context.
  • Participants discuss the formulation of the epsilon-delta proof, questioning the correctness of their expressions and the relationship between ε and δ. There are attempts to express δ in terms of ε, with some confusion about the implications of their calculations.
The discussion is ongoing, with participants providing feedback on each other's reasoning. Some guidance has been offered regarding the need to express δ as a function of ε, and there is a focus on clarifying the bounds for δ to ensure the proof holds. Multiple interpretations of the problem are being explored, particularly regarding the values of δ and the behavior of the function near the limit.
Participants are navigating the complexities of epsilon-delta proofs for the first time, which may contribute to misunderstandings about the relationships between the variables involved. There are also constraints regarding the assumptions made about the values of x in relation to the limit.
Hollysmoke
I'm supposed to prove that lim x -> -2, x^2+3x+7 = 5
Here's what I have:
|x^2 +3x+7 – 5| < ε
|x+2| < δ
|x^2+3x+2| -> |(x+2)(x+1)| < ε whenever |x+2| < δ
|x+1||x+2| < δ |x+1|
|x+1||x+2| < δ|x+1| < ε
ε / |x+1| > δ , as x -> -2, |x+1| -> 3,
therefore: ε / -1 > δ
But I'm not sure if I did it correctly, since its our first time using quadratic. Help, please?
So what's your final answer? Remember, given an ε>0, you're supposed to find a δ such that ... Thus δ should be written as a function of ε. So what is your δ?
I thought that was enough...where did I go wrong?
I'll ask again. What is delta?
I get delta = min {1, e/0}
e/0? That doesn't make sense. You're pretty close to the answer in your first post.
|x+1||x+2| < δ |x+1|
ε / |x+1| > δ
This part is mostly correct. You've shown that if |x+2|<δ and δ<ε/|x+1|, then |(x2+3x+7)-5|<ε. What you need to do is find δ in terms of ε only (not x) such that if |x+2|<δ then |(x2+3x+7)-5|<ε. How can you replace |x+1| in the expression you found with a constant that maintains the inequality?
We need to find such a number that restricts x to lie in some interval centered at 2, right?
Well, yea, that's what delta is. The problem is finding delta.
since it's a value close to -2, can we assume that it is within a distance 1 from -2, that is, -1<x+2<1 , -3 < x < -1
Here's where I was confused: Do I add 1 since the other value was x + 1? so, I'd be -2 < x + 1 < 0 ?or x + 1 < 0 ?
Then it'd be delta = e / 0
e/0 does not make any sense.
You can just enforce that δ<1/2, so that you don't need to worry about |x+1|=0.
It should be e / 1, since the limit is approaching -2, then -1 < x+2 < 1, or x+2 < 1, so delta = 1 and e / 1 ?
No, because -2-δ<x<-2+δ, so x may be less than -2. If you set δ<=1/2 as I suggested (ie, whatever expression you might end up with, just put δ=min{1/2,...}), then you know that 1/2<=|x+1|<=3/2 (the bound might end up even better than this, but this is all you need).
How and why did you write the line:
|x+1||x+2|<δ|x+1|
It seems to come out of nowhere. I don’t understand.
  • · Replies 22 ·
