Is Log(x) Continuous on the Interval (0, ∞)?
  • Thread starter Thread starter Yagoda
    Continuous
The discussion centers on proving that the function f(x) = log(x) is continuous on the interval (0, ∞) by leveraging its continuity at x = 1 and the property log(xy) = log(x) + log(y). Participants explore using the epsilon-delta definition of continuity, suggesting that continuity at x = 1 can be extended to other points in the interval. One approach involves rewriting log(x) in terms of log(1) to facilitate the proof. The conversation highlights the challenge of applying the two given facts effectively to demonstrate continuity across the entire interval. Ultimately, the aim is to establish a valid proof that confirms the continuity of the logarithmic function.
Yagoda
Prove that f(x)=\log x is continuous on (0, \infty) using that
(1) f is continuous at x=1 and
(2) \log(xy) = \log(x) + \log(y)
The definition of continuity: for all \epsilon >0, there exists a \delta>0 such that if |x-x_0| < \delta then |f(x) - f(x_0)| < \epsilon.
I think I've figured out how to do this using a more standard epsilon-delta proof, but it doesn't really make use of the two facts.
From what I can tell, it seems like you trying to be able to use the continuity at x=1 to "slide" the continuity down to 0 and up to infinity, but I'm not sure how to do this in a valid way. The only way I've managed to use fact 2 is rewrite things like \log x = \log(x \times 1) = \log(x)+\log(1) = \log(x), which hasn't gotten me very far.
Try replacing x_0 with xy for some y.
Likes 1 person
Look at ##f(x) - f(x_0)##, this becomes ##log(x) - log(x_0)##.
hint
log(x+h)-log(x)=log(1+h/x)-log(1)
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 40 ·
  • · Replies 26 ·
