Proving Set of Lipschitz Functions of Order b in Order a
The discussion revolves around proving properties of Lipschitz functions, specifically showing that the set of Lipschitz functions of order b is contained within those of order a, where 0 < a < b <= 1. Additionally, participants are exploring whether the set of Lipschitz functions of order b forms a closed subspace of those of order a.
  • Participants discuss the implications of the Lipschitz condition and attempt to derive relationships between the constants and the orders of Lipschitz continuity. There are questions about the rigor of certain steps and the use of variables in the context of the problem.
Several participants have provided insights and suggestions regarding the mathematical relationships involved in the problem. There is ongoing exploration of the implications of the inequalities and the constants involved. Some participants express confusion about specific hints and terminology, indicating a need for clarification.
Participants note the importance of distinguishing between the endpoints of the interval and the exponents in the Lipschitz condition. There is also discussion about the significance of the relationship between a and b, particularly that 0 < b-a < 1.
Carl140
1. Let 0 < a < b <= 1. Prove that the set of all Lipschitz functions of order
b is contained in the set of all Lipschitz functions of order a.
2. Is the set of all Lipschitz functions of order b a closed subspace of those
of order a?
I know that a function f: [a,b] -> R is Lipschitz of order a if there exists a constant K
such that |f(x) - f(y)| <= K |x-y|^a and for all x,y in [a,b].
Assume f is a Lipschitz function of order b then there exists some constant K such that
|f(x)-f(y)|<= K |x-y|^b. Then I need to prove that we can find some constant say C
such that |f(x) - f(y)| <= C |x-y|^a , where 0 < a < b=1.
Then I don't know how to proceed. Can you please help?
Fix a and b. Have you considered the equality K|x - y|b = K|x - y|a|x - y|b - a ?
OK, thanks for your reply.
So |f(x)-f(y)|<= K |x-y|^b implies |f(x)-f(y)|<= K |x-y|^a |x-y|^(b-a).
Therefore: |f(x) - f(y)| /|x-y|^a <= |x-y|^(b-a)
But x and y are both in [a,b] so |x-y| <= |x|+|y| = b + b = 2b.
Therefore |f(x)-f(y)|/|x-y|^a <= (2b)^(b-a).
So our constant C is then (2b)^(b-a). Is this OK?
How to show the closedness part? I know I have to take a sequence and show its closed
under the limit but really I have no clue how to proceed.
What happened to K?
The first equality does not make sense, x and y are variables. Add some more rigor to your statements.
OK, thanks again.
My try:
Since f is Lipschitz of order b then there exists a constant K >0 such that
for all x, y in [a,b] we have: |f(x)-f(y)|<= K |x-y|^b.
Observe K|x-y|^b = K|x-y|^a |x-y|^(b-a).
Therefore |f(x)-f(y)| <= K |x-y|^a |x-y|^(b-a) and thus:
|f(x)-f(y)|/|x-y|^a <= K |x-y|^(b-a).
Since x, y are points in [a,b] then |x-y|^(b-a) <= (2b)^(b-a).
Therefore |f(x)-f(y)|/|x-y|^a <= K (2b)^(b-a) and hence:
|f(x)-f(y)|<= K (2b)^(b-a) |x-y|^a so f is Lipschitz of order a with constant
C = K (2b)^(b-a).
OK?
Carl140 said:
OK, thanks again.
My try:
You appear to be using a and b with two different meanings here. I think more important is that since a< b< 1, 0< b-a< 1.
C = K (2b)^(b-a).
OK?
Halls: Sorry, I do not follow your hint/suggestion, what do you mean?
Two things that Hall mentioned:
1) You are denoting the endpoints of the closed interval with the same constants you are using to denote the exponents of the Lipschitz inequality. The two are not related; if necessary use different letters, like [c, d].
2) The fact that 0 < b-a < 1 is important.
Gotcha guys.
|f(x)-f(y)| / |x-y|^a<= K |x-y|^(b-a).
Since 0 < b-a< 1 then |x-y|^(b-a) < |x-y|.
Actually I meant: then |f(x)-f(y)|/|x-y|^a <= K |x-y|^a |x-y|. But x,y are both points in [c,d] so |x-y| <= d.
Thus we get |f(x)-f(y)| <= K |x-y|^a * d so the constant is C = k*d, correct?
Well since a and b are endpoints, and x,y are any points in [a,b], the inequality |x-y| =< |b -a| holds, so I don't think you need any extra variables beyond what's given in the problem statement.
