Proving Normality of [0] in Z/3Z Quotient Group
The discussion focuses on proving that the equivalence class [0] in the quotient group G = Z/3Z is a normal subgroup. The user demonstrates understanding by showing that for any g in G and n in N, the condition gng-1 = n' holds true due to the abelian nature of the group. The user correctly identifies that the identity element 0 behaves multiplicatively as 0.0-1 = 0, reinforcing the normality condition for additive groups. The conversation also clarifies the notation and operations used in both additive and multiplicative contexts within group theory.
  • Understanding of quotient groups, specifically Z/3Z
  • Familiarity with normal subgroups and their properties
  • Knowledge of group operations (additive vs. multiplicative)
  • Basic concepts of abelian groups
  • Study the properties of normal subgroups in various group structures
  • Learn about the implications of abelian groups on subgroup normality
  • Explore the differences between additive and multiplicative group operations
  • Investigate the structure of finite groups, particularly Z/nZ
Mathematics students, particularly those studying abstract algebra, group theory enthusiasts, and educators looking to clarify concepts of normal subgroups and group operations.
nigelscott
I am looking at the quotient group G = Z/3Z which is additive and abelian. The equivalence classes are:
[0] = {...,0,3,6,...}
[1] = {...,1,4,7,...}
[2] = {...,2,5,8,...}
I want to prove [0] is a normal subgroup, N, by showing gng-1 = n' ∈ N for g ∈ G and n ∈ N. Since G is abelian so gg-1n = n' ∈ N. The identity element 0 is also in G so I should be able to write 0.0-1n = n'. How do I interpret 0.0-1?
My first thought was that since the inverse of the identity is the identity then 0.0<sup>-1</sup> = 0. Therefore, this would give 0n = n' = 0. This is also consistent with 0n = n0. However, I am still not sure about this because the identity is being used multiplicatively and not additively.
You should not use ##0## if you write the group operation as multiplication, in which case the elements are ##\{\,1,2,3\,\}##. If you write it as addition, then the normality condition will be ##x+N-x\ \subseteq N##.
OK. So is it fair to generalize by saying that ene-1 = n applies to multiplicative groups where e = 1 and that e + n + (-e) = n applies for additive groups where e = 0? This makes intuitive sense but most of the literature I have read seems to focus on the multiplicative case.
The convention is to write a group multiplicative, because they are usually not Abelian and we are used to associate commutativity with addition. So if a group is Abelian, then it is sometimes written as addition. But it's confusing to see things like ##x+N-x \subseteq N##. You can still use your notation of equivalence classes: ##[0],[1],[2]## and write the group operation as multiplication, but you will have ##[0]\cdot [x]=[x]## and ##[2]^{-1}=[1]##. In this case it would be best to write ##\mathbb{Z}/3\mathbb{Z} = \mathbb{Z}_3 = \{\,1,a,a^2\,\}##. The reason is, that ##\mathbb{Z}_3## is even a ring and a field, so both operations are necessary. Of course the multiplicative group of ##\mathbb{Z}_3## as a ring or field doesn't have a zero in it, so we can use ##[0],[1],[2]## as elements. However, in your case, the group with three elements is considered, so either write ##\mathbb{Z}_3 = (\{\,1,a,a^2\,\},\cdot )## or ##\mathbb{Z}_3 = (\{\,0,1,2\,\},+)##.
Thanks, makes more sense now.
  • · Replies 26 ·
