Proving Subspace of ℝ^{n} from Linear Algebra Homogeneous System
The discussion revolves around proving that the set of solutions to a homogeneous system of linear equations in multiple variables forms a subspace of ℝ^{n}. Participants are exploring the definitions and properties of subspaces in the context of linear algebra.
  • Conceptual clarification, Assumption checking, Problem interpretation
  • Participants are attempting to understand the relationship between the rank of the coefficient matrix and the nature of the solutions to the homogeneous system. Questions are raised about whether the requirements change for homogeneous systems compared to non-homogeneous ones.
Some participants are questioning the necessity of knowing the rank of the matrix to prove the subspace property, while others emphasize the importance of closure under addition and scalar multiplication. There is an ongoing exploration of the implications of these properties in relation to the solutions of the system.
There is mention of specific examples and the dimensionality of solution sets, as well as references to textbook theorems that may influence the understanding of the problem. Participants are also discussing the requirements for a set to be classified as a subspace.
ChemistryNat
SHow that the set of solutions to a homogenous system of m linear equations in n variabes is a subspace of [itex]ℝ^{n}[/itex] (Show that this set satisfies the definition of a subspace)
If {V1,...Vk}=[itex]ℝ^{n}[/itex] then every vector [itex]\vec{q}[/itex][itex]\in[/itex]ℝ can be written as a linear combination of the set
c1V1+...+ckVk=[itex]\vec{q}[/itex]
This system of linear equations must have a solution for every [itex]\vec{q}[/itex][itex]\in[/itex]ℝ and therefore the rank of the coefficient matrix = n
If the rank of the coefficient matrix of a system
c1V1+...+ckVk=v
is n, then the system is consistent for all V[itex]\in[/itex]ℝ
∴ {V1,...,Vk}=[itex]ℝ^{n}[/itex]
I thought I was on the right track, but a theorem in my textbook says
" Let [A|[itex]\vec{b}[/itex]] be a system of m linear equations in n variables. Then [A|[itex]\vec{b}[/itex]] is consistent for all [itex]\vec{b}[/itex]=[itex]ℝ^{n}[/itex] if and only if rank(A)=m"
Does the requirement change is they are homogenous? Am I even on the right track?
c1V1+...+ckVk=v
You are on the wrong track. You need to worry about the rank of the matrix. For example, what is the dimensionality of the solutions to the following linear system?
[tex]x_1 + x_2 + x_3+ x_4 = 0\\<br /> 2x_1 + 2x_2 + 2x_3 + 2x_4 = 0[/tex]
I think you're making this much harder than it needs to be. You don't need to know the rank of the system.
A homogeneous system can be written as follows: ##Ax = 0##, where ##A## is some matrix.
A vector ##x## is a solution to the system if and only if ##Ax = 0##. So the set of solutions is precisely the set of vectors which satisfy the equation.
What are the requirements to show that a set is a subspace?
Not sure what you mean by dimentionality of the system
but the RREF form yields the system
[tex]x_1 + x_2 + x_3+ x_4 = 0[/tex]
Set is a subspace if it is closed under addition and scalar multiplication (and therefore include the zero vector)
Yes, and that is my point exactly: the matrix has rank 1, so the dimensionality of the solution set is 4 - 1 = 3. This counters your statement in the OP that the rank of A is n.
However, as has already been pointed out, you don't even need to know this to do the question; you would need to know it if you were asked about the dimension of the subspace.
OK, let's start with addition. If ##x## and ##y## are solutions, what can you say about ##x+y##?
That x+y is also a solution? It should be if it's closed under addition
Are you asking me or telling me? You need ##A(x+y) = 0##. Is it true? If so, why?
  • · Replies 26 ·
