Pulley Torque Calculations for Motor with Added Pulley: Is the Torque Affected?
The discussion revolves around the effects of adding a pulley to an electric motor's shaft on the torque output. Participants explore the relationship between torque, force, and distance, considering both theoretical and practical implications of the setup.
  • Some participants suggest that the torque remains constant at 1450 Nm regardless of the pulley size, as the torque is a property of the motor itself.
  • Others argue that the resultant force changes with the radius of the pulley, leading to different forces being applied at different points in the system.
  • One participant introduces the concept of torque couples and relates it to the operation of the motor, suggesting that the motor generates a pure moment.
  • There is confusion regarding the calculations of force and torque, with some participants questioning the appropriateness of using radius versus diameter in calculations.
  • Some participants express uncertainty about how the weight of the pulley and belt might affect the torque in practical scenarios.
  • A participant reflects on the relationship between torque and power, noting that while torque may not change, the speed and resultant force will vary with the pulley size.
  • Another participant seeks clarification on the calculations involving torque and resultant forces, indicating some misunderstanding of the units and concepts involved.
Participants do not reach a consensus on whether the torque changes with the addition of the pulley. Multiple competing views remain regarding the relationship between torque, force, and radius, as well as the implications of practical considerations like weight.
Some calculations presented by participants are based on assumptions that may not hold in practical applications, such as neglecting the weight of the pulley and belt. There is also confusion regarding the use of units and the interpretation of torque in relation to radius and diameter.
This discussion may be useful for individuals interested in mechanical engineering, physics, or anyone working with electric motors and pulley systems, particularly in understanding the nuances of torque and force relationships in practical applications.
M.E. Tom
I think I'm over thinking this, so someone set me straight.
If I have an eletric motor with a 75mm OD shaft making 1450Nm of torque, and
I add a 7in pulley/sheave to the motor shaft.
Would the torque change? Half of me says yes other half of my brain thinks no.
Torque = Force * distance
1450Nm/(0.075m/2)=19333.3N at the edge of the motor shaft.
Now at the 7in Pulley that is bolted to the shaft
19333.3N*0.0889m= 1718.73Nm (0.0889m--> 3.5in-->half of 7in pulley)
Is this right? or would you still have the 1450Nm of torque at the 7in pulley?
I think you would still have 1450Nm at the 7inch pulley. i am saying this cause the axis of the shaft and the pulley are the same.
I am a little confused though abt the calculation that u did with torque = force*distance.
in a torque a couple acts and in a moment a force acts. the calculation would have been correct if u were calculating moment, but as u are calculating the torque i think u should multiply the diameter instead of the radius. its like turning a nut with a wrench; a couple is formed between the normal and the force applied and u multiply it with the distance between the two that is the length of the wrench. here the couple is formed inside the motor in the coils with the dia as the distance between them.
now when you put a pulley on the shaft, no extra force acts and the same torque acts at the axis of the pulley. its like in an engine, the torque of the engine gets transferred to the tire.
the doubt tht i have is if the torque would be effected by the weight of the pulley and the belt you would put on it later cause your talking about a practical problem. (in theory they usually asume the masses as negligible.)
I had completely forgotten about Torque copules.
From Wikipedia: A Couple is a system of forces with a resultant (a.k.a. net, or sum) moment but no resultant force. Another term for a couple is a pure moment. Its effect is to create rotation without translation, or more generally without any acceleration of the centre of mass.
So, this is exactaly what and electric motor is a pure moment.
I guess what keeps blowing my mind is if I look at this assembly like the attached picture.
If I apply force F1, large enough to sall the motor, then the force required to stall it will be less at F2. Therefore, the force at F2 would be what is aviable to the belt and next pulley.
Thought comment suggestions on this?
Oh I noticed a error in my previous calculation
1450Nm/(0.075m/2)=38666.67N
38666.67N*0.0889m=3437.5Nm
I may be oversimplifying here but...
No, the torque doesn't change. You have 1450 Nm of turning force - whether it is applied over a small or large distance, it remains 1450 Nm.
Think of a bolt that requires 100 Nm of tightening torque. You have a socket set with 2 bars, one 1.0 m long and one 0.5 m long. To apply the same torque to the bolt, the 1.0 m bar requires 100 N applied to the end. The 0.5 m bar requires 200 N applied. In your example, the torque applied by your motor to a small shaft or a large pulley will be the same. 1450 Nm.
The resultant force will not - it will vary in proportion to the radius. A shaft of (e.g.) 0.1 m will produce a tangent force of 14,500 N (1,450 N / 0.1 m) and a pulley of (e.g) 1.0 m will produce a tangent force of 1,450 N (1,450 N / 1.0 m).
It may help to imagine your shaft and pulley as 2 different levers welded to the motor spindle. One is 37.5 mm long (the shaft) and one is 88.9 mm long (the pulley). Clearly the shorter lever will need more force to stall the motor.
From
http://en.wikipedia.org/wiki/Newton_metre"
A Newton metre is a unit of torque (also called "moment") in the SI system. The symbolic form is N m or N·m,[1] and sometimes hyphenated Newton-metre. One Newton metre is equal to the torque resulting from a force of one Newton applied perpendicularly to a moment arm which is one metre long.
You're not thinking you can amplify power with a pulley, are you...?
No, I understand that power is constant through the belted drive, the torque and speed change to keep this constant.
Bandit127, you hit on my though exactly with your example
Because, I keep thinking about it in that way. As a 3.5in(88.9mm) lever driving the belt, therefore I want to take the resultant force from the 7in motor pulley and multiply it by the radius of the 34in pulley to determine the torque applied at the larger pulley. (7in and 34in make up stage 1 in my belt drive) 1450Nm/0.0889m=16310.5N leaving the 7in motor pulley.
Torque at the 34in pulley is 16310.5N*0.4318=7042Nm
Instead of doing 1450NM (34/7)= 7042Nm Which makes the assumption that the resultant force is equal.
Ok, Light bulb moment, I see the error in my thinking. In my initial question I was trying to calculate a different torque at the motor pulley, which cannot happen, but I can have a different resultant force at the larger radius.
So continuing on through the drive train, pulley #2 (34in one from above) and pulley #3 (10in OD) are rigidly fixed on the same axle/jackshaft. Therefore torque in = torque out, power in=power out and rpm in =rpm out. We know the torque from above at the 34in pulley is 7042Nm. The resultant force at Pulley #3 is 7042Nm/0.127m=55448.8N Moving out to Pulley #4 with a 33in od. The torque is 55448.8N*0.4191=23238.6Nm (7042Nm*(33/10)=23238.6Nm)
Thanks guys for all your help.
If you change the diameter, the velocity at the circumference will change. To conserve the energy, torque at the circumference must change also. Greater radius will result in less torque. This means that the torque at the circumference of the 75mm shaft is 38666.67 N/0.0375m, and for the 7 in pulleys circumference about 16310.46 N/0.0889m.
However, as torque is measured at 1m radius, it would not change in your example.
Vidar
Vidar,
Could you go into a little more detail?
Also, torque is in Nm not N/m so I'm confused by your example.
You used the motor torque of 1450Nm divided by the moment arms (0.0375m, 0.0889m)
to calculate the resulant force for each
So basically (1450Nm/0.0375m)/0.0375m=1031111N/m
Where is the 1m radius coming from?
M.E. Tom said:
Vidar,
The one meter radius is an imaginary radius where the torque usually is measured at. IF you had a flywheel with 1m radius, the circumference would have 1450Nm torque - That would be 1450 Newtons per meter radius.
If your motor have a shaft of only 75mm, the radius is only 37.5mm, or 0.0375m. The force at the shafts circumference would therfor be 1450Nm/0.0375m which is 38666.666N.
The greater the circumference is, the less force will apply to it.
Hope my corrections helped you out.
Vidar
Pulley Torque
lets simplify this
HP*5252/RPM=TORQUE FTLBS
MOTOR HP 2
MOTOR RPM 1725
2*5252/1725=6.08 FTLBS TORQUE
ADD A DRIVING PULLEY 3 INCH AND A DRIVEN PULLEY 5 INCH TO THIS AND THROUGH REDUCTION WE WILL INCREASE TORQUE.
1725*3/5=1035 RPM 2HP*5252/1035RPM=10.14 OR 10 FTLBS TORQUE LESS INEFF. OF PULLEYS MOTOR ETC.
  • · Replies 24 ·
  • · Replies 19 ·
  • · Replies 36 ·
26K
