How to Calculate Force and Tension in a System of Blocks?
  • Thread starter Thread starter Paymemoney
    Blocks
The discussion focuses on calculating the force and tension in a system of three identical blocks connected by strings on a frictionless surface. The tension between blocks B and C is given as 3.00 N, and each block has a mass of 0.400 kg. The user attempts to find the total force F and the tension T_AB between blocks A and B using the equations of motion, but encounters discrepancies in their calculations. Key points include the correct application of F=ma and the realization that vertical forces do not affect horizontal motion. The user seeks clarification on their errors to arrive at the correct answers for both force and tension.
Paymemoney
Three identical blocks connected by ideal strings are being pulled along a horizontal frictionless surface by a horizontal force F_vec. The magnitude of the tension in the string between blocks B and C is T = 3.00 {\rm N}. Assume that each block has mass m = 0.400 {\rm kg}.
a)What is the magnitude F of the force?
b) What is the tension T_AB in the string between block A and block B?
http://img340.imageshack.us/img340/3789/9374t.jpg
W=mg
F=ma
a) i made A and B as one object and calculated the acceleration of the object
two forces are acting on this object.
1st force
w=mg
w=0.4*9.8
W=3.92N
2nd force is tension = 3N
Found Fnet to be 3+3.92+4.94
Fnet = 11.86
used F=ma formula
a=11.86/0.4
a=29.65m/s^2
then to find the force i went: a=Fnet/3m
so a=11.86/3*0.4
a=9.88m/s
To find force i use 9.88 * 0.4 = 4N ------> answer's says it 4.50N (tell me where i have gone wrong)
b) Used f=ma
f= 29.65 * 0.4
=11.86 i know this is incorrect, but someone tell me the correct way of doing this.
P.S
1st force
w=mg
w=0.4*9.8
W=3.92N
There's also the upward normal force acting on the blocks, which exactly cancels the weight. (Since there's no acceleration in the vertical direction.)
Fnet = 11.86
I thought you said there were two forces acting on the blocks? And since these forces act in different directions, they can't just be added like numbers.
Hint: The vertical forces add to zero, so they can be ignored.
  • · Replies 25 ·
