Punctual and uniform convergence
7 replies · 3K views · last reply
Kernul
##I## a set of real number and ##f_k : I \rightarrow \mathbb{R}## a succession of real functions defined in ##I##.
We say that ##f_k## converges punctually in ##I## to the function ##f : I \rightarrow \mathbb{R}## if
$$\lim_{k \to \infty} f_k(x) = f(x), \hspace{1cm} \forall x \in I$$
Which is like saying:
$$\forall \epsilon > 0,\hspace{1mm} \forall x \in I,\hspace{1mm} \exists \nu_{\epsilon, x} \in \mathbb{R} : |f_k(x) - f(x)| < \epsilon \hspace{1cm} \forall k > \nu_{\epsilon, x}$$
What is the ##\nu_{\epsilon, x}##? Is it the same in the normal succession of real numbers? Could someone make some examples?
And I've read that for the uniform convergence, this ##\nu_{\epsilon, x}## depends only from ##\epsilon##, so ##\nu_{\epsilon}##, and that the uniform convergence implies the punctual convergence but not vice versa. Any example with these too?
You may consider the sequence ##f_k := \max \{k-k^2\cdot \,\vert \,x-\frac{1}{k}\,\vert \, , 0\}## and ##f(x)=0## as its limit.
Covergence here is ##f_k \longrightarrow f##. That is ##f_k(x) \longrightarrow f(x)##. Now the ##\nu## define in a way how fast this is because they (usually) become bigger the smaller the ##\epsilon## is. So the difference between punctual and uniform convergence is basically whether this "speed of convergence" is the same at all points ##x##, in which case we call it uniform, or whether this "speed of convergence" depends on where we are on the ##x-##axis, in which case it is only punctual.
One example of punctual converge is how the function ##f_{n}(x) = e^{-x^{2n}}## approaches the function "##g : g(x) = 1## if ##|x|<1##, ##g(x) = 1/e## if ##|x| = 1##, ##g(x) = 0## if ##|x|>1##" when the natural number ##n## grows without bound. If you set ##\epsilon = 0.05##, there will always be a point ##x## for which ##f_{n}(x) = 0.9## and outside the chosen bounds, no matter how large ##n## is.
An example of uniform convergence is how the sequence ##f_{n}(x) = x + 1/n## approaches ##g(x) = x## when ##n\rightarrow \infty##
I've never seen it described as "punctual" convergence. The English words point and punctual are derived from Latin "punctum," but the usual meaning of punctual is "on time," as in a punctual arrival of a student to a class.
The type of convergence discussed in this thread is called "pointwise" convergence in English.
Oh, I get the ##\nu## part, but why the limit is ##f(x) = 0##?
Why if setting ##\epsilon = 0.05##, we have ##f_n(x) = 0.9##?
Yes, you're right. I'm sorry but I'm not a native English speaker. When I translated from my native language (Italian) to English, I thought it was correct.
##f_k(x) = max \{k-k^2\,\vert \,x-\frac{1}{k}\,\vert \,\, , \,0\}##.
So the only values ##f_k(x) \neq 0## are in the interval ##]0,\frac{2}{k}[## which is getting smaller by increasing ##k##. Hence we have only to consider the point ##x_0=0##. But ##\lim_{k \rightarrow \infty}f_k(x_0)=0## because you can always find a zero in a small neighborhood of ##x_0##, although the values at exactly ##x_0## are large.
The function ##f_n## goes through all values in the interval ##]0,1]## no matter what the number ##n## is, because it's a continuous function. Therefore we know that for any ##n##, there are points where the function's value differs from the limit ##g(x)## by more than the number ##\epsilon = 0.05## (note that the function ##g## always has value 1, 1/e or 0). This is just a single example that is sufficient to prove that the function sequence ##f_n## is not uniformly convergent.
The order of quantifiers is important. "...for each ... there exists..." can have a different meaning than "...there exists... for each...".
For example:
"For each instrument X there exists a virtuoso Y such that Y plays X "
versus
"There exists a virtuoso Y such that for each instrument X, Y plays X".
The first statement is a modest claim. The second statement asserts the existence of a fantastic musician who is a virtuoso at playing every instrument.
In pointwise convergence, the definition uses the order "...for each x ...there exists a ##\nu##..."
In uniform convergence, the definition uses the order "...there exists a ##\nu## ...for each x...".
The sequence ##f_k(x)## converges pointwise to ##f(x)## on the interval ##I## is the more modest claim that:
For each ##\epsilon > 0## and for each ##x \in I##, there exists a ##\nu## such that if ##k \gt \nu## then ##|f(x) - f_k(x)| \lt \epsilon##.
The sequence ##f_k(x)## converges uniformly to ##f(x)## on the interval ##I## is the grander claim that:
For each ##\epsilon > 0## there exists a ##\nu## such that for each ##x \in I ##, if ##k \gt \nu## then ##|f(x) - f_k(x)| \lt \epsilon##.
