PV diagram of a monatomic ideal gas
The discussion focuses on calculating the work done and internal energy change for a monoatomic ideal gas transitioning from state A to state D via a PV diagram. The total work done by the gas is determined to be 2020 J, calculated from two segments: 808 J for the isobaric process A-E and 1212 J for the isothermal process E-D. The change in internal energy and heat flow into the gas can be derived using the first law of thermodynamics, specifically the equation dU = Q + W and the formula dU = (3/2)nRT.
  • Understanding of the ideal gas law and monoatomic gas properties
  • Familiarity with thermodynamic processes: isobaric and isothermal
  • Knowledge of the first law of thermodynamics
  • Ability to interpret PV diagrams
  • Study the ideal gas law and its applications in thermodynamics
  • Learn about the derivation and application of the first law of thermodynamics
  • Explore the concept of work done in thermodynamic processes
  • Investigate the significance of PV diagrams in visualizing gas behavior
Students studying thermodynamics, physics educators, and professionals working with gas laws and thermodynamic systems.
mikefitz
Suppose 0.50 mol of a monoatomic ideal gas is changed from state A to state D by one of the processes shown on the PV diagram of the figure below.
http://img382.imageshack.us/img382/784/untitledsc4.png
(This is my edited version of the image)
(a) Find the total work done by the gas if it follows the constant pressure path A-E followed by the constant temperature path E-D.
(b) Calculate the total change in internal energy of the gas during the entire process and the total heat flow into the gas.
I'm having trouble with (a). Is the work done from path A-E, E-D reflected on the first diagram I made, or the second? I guess I'm confused as to whether I'm supposed to use 1 or 2 atm in my calculations. thanks
Hi Mikefitz,
It has been a while since i touched my thermodynamics but nevertheless i'll try to help.
For part (a),
U need to know that 1 atm = 1.01 x 10^5 Pa and 1 litre = 1000 cm³ = 0.001 m³
Work done from A-E (isobaric) = P dV = 2 x 1.01 x 10^5 Pa x (8-4) x 0.001m³ = 808 J
Work done from E-D (isothermal) = Area of trapezium E-D = 1/2 (2+1) x 1.01 x 10^5 Pa x (16-8) x 0.001m³ = 1212 J
Total work done by gas (expansion) = 808 J + 1212J = 2020 J
For part (b),
U use the 1st law of thermodynamics, dU = Q + W or dU = 3/2nRT to solve for the change in internal energy, dU and heat flow, Q, into the gas.
Hope my A level physics helps. Correct me if I'm wrong.
  • · Replies 33 ·
