Pythagoras' Perfect Ratios: Uncovering the Base 10 Anomaly
A 49-year study reveals a significant anomaly in the Base 10 number system, linked to Pythagorean ratios (0:1:1:2:3:4) and their relation to the area of circles. The formula 9^2 (10) (DD) is introduced, where 9 represents the diameter, (10) signifies Base 10, and (DD) denotes the degree-distance between angular degrees of a circle. This formula consistently yields the area for any diameter, demonstrating a universal application of the Base 10 system. Examples illustrate this with various diameters, confirming the anomaly's validity. The discussion invites further exploration and understanding of these mathematical concepts.
Robust
Base 10 Anomaly
An applied 49-year study into the origin of pi and the Base 10 number system resulted in the finding of a highly anomalous formula. Essentially, the finding derives from the perfect ratios (0:1:1:2:3:4) given by Pythagoras who we know studied and perhaps taught in the Babylonian temples of learning. Unquestionably the cipher given of his perfect ratios relates of Base 10 - all cardinal numbers of the system relating of diameter to the circular plane. Here is the formula succinctly given - you can take it from there.
9^2 (10) (DD) = area; where 9 is culmination to Base 10 and diameter of circle; (10) is Base 10 (recognized by Pythagoras as given by the cipher); (DD) is the degree-distance between each angular degree of the 360-degree circumference, given as pi/40 for the diameter of 9. The anomaly is seen where the degree-distance as given by the diameter applies to giving the area to a circumference of any diameter whatsoever. Here are several examples, noting that the DD to a diameter of 9 is employed in every instance:
9^2 (10) (0.07853...) = 63.6172...area;
8^2 (10) (0.07853...) = 50.2654...area;
7^2 (10) (0.07853...) = 38.4845...area; etc., and for any diameter whatsoever.
Like Root 2, Base 10 rules.
"All things number and harmony." - Pythagoras
Eh? Could someone explain this or give a link to read to make sense of it please.
Hi, Zurtex! What is there about it you would like to know? I'll help as I can.
Dondes back!
Rubbish.
- Warren
comparing a flat solar panel of area 2π r² and a hemisphere of the same area, the hemispherical solar panel would only occupy the area π r² of while the flat panel would occupy an entire 2π r² of land. wouldn't the hemispherical version have the same area of panel exposed to the sun, occupy less land space and can therefore increase the number of panels one land can have fitted? this would increase the power output proportionally as well. when I searched it up I wasn't satisfied with...
