Q: Electromagnet - Insulated vs Bare
  • Thread starter Thread starter DkEnrgyFrk
    Electromagnet
Both insulated and bare wire can be utilized to create an electromagnet, with the effectiveness depending on the type of wire, current flow, and number of coils. Insulated wire, often coated with a thin layer of varnish or enamel, allows for close winding of coils without short-circuiting, enhancing inductance. Conversely, bare wire provides better electrical conduction, potentially resulting in a stronger magnetic field. The choice between insulated and bare wire is not a matter of right or wrong but rather a consideration of safety and desired performance.
  • Understanding of electromagnetism principles
  • Familiarity with wire types, specifically insulated and bare wire
  • Knowledge of current flow and its impact on magnetic fields
  • Basic safety precautions when working with electrical components
  • Research the properties of enamel-coated wire for electromagnet applications
  • Explore the relationship between coil turns and inductance in electromagnets
  • Investigate safety measures when using bare wire in electrical projects
  • Learn about the effects of current variations on electromagnet strength
Electronics enthusiasts, hobbyists building electromagnets, and educators teaching electromagnetism concepts will benefit from this discussion.
DkEnrgyFrk
There is a post on this forum stating that the insulation should be left on the wire to prevent a short circuit thus making the electromagnet ineffective. Lost the link and can't find it now.
But I am finding multiple articles on the internet that are using bare wire.
Ex of bare: http://www.wikihow.com/Create-an-Electromagnet
Ex of insulated: http://www.energizer.com/learning-center/science-center/Pages/make-electromagnet.aspx
There are multiples on the web of both versions of creating the electromagnet, both insulated and non.
Why is either version working? Is there a right way or a wrong way?
The information provided in first article is incorrect. Look at the pictures, they seem to be just collected from here and there. The cable in first picture is different, wires are smaller. Then in next two pictures the wire is thicker. And see, if the wire is not insulated, the iron nail would short circuit it.
Ideally, the coil wire should always have insulation on it. The wire for making coils, using in transformers, inductors etc. comes with a tiny varnish or enamel coating so the insulation is very thin. This type of wire visibly looks like non-insulated but its not. The closer the turns of coil are, the better its inductance - this is why special enamel coated wire is used - it allows you to make turns very close but still insulated.
If you use an ordinary non-insulated wire, one possible thing to do, is carefully wind the turns close but not touching each other. But this way inductance won't be very good.
so true ... gosh I can't believe how much garbage there is on the net for something that is so simple to make
I even left a message posted on the first link stating the pobvious fault ;)
Dave
Thank you both for confirmation.
I would like to clarify that both insulated and bare wire can be used to create an electromagnet. The key factor here is the flow of electricity through the wire, not the presence or absence of insulation.
Insulation is used to prevent the flow of electricity and to protect the wire from damage. In the case of an electromagnet, the flow of electricity is necessary to create a magnetic field. Therefore, insulation is not necessary for the functioning of the electromagnet. However, it may be used for safety purposes.
On the other hand, bare wire allows for better conduction of electricity, which can result in a stronger magnetic field. This is why some sources may recommend using bare wire for making an electromagnet.
Ultimately, the effectiveness of an electromagnet depends on factors such as the type of wire, the amount of current flowing through it, and the number of coils. Both insulated and bare wire can work effectively in creating an electromagnet, and there is no right or wrong way to do so. It is important to follow proper safety precautions and use the appropriate materials for the desired outcome.
10K
11K
9K
15K
  • · Replies 73 ·
9K
  • · Replies 46 ·
