QFT: differential cross section from center of mass to lab frame
The discussion focuses on the conversion of the differential cross section from the center of mass (CM) frame to the lab frame for a photon-nucleus interaction resulting in a pion and a nucleus. The user has computed the squared matrix element |M|² and the differential cross section dσ/dΩCM in the CM frame. They seek a systematic approach to derive dσ/dΩlab, particularly under the limit of an infinitely massive nucleus (MN→∞). The key relationship utilized is (dσ/dΩ')lab dΩ' = (dσ/dΩ)CM dΩ, which ensures the conservation of the number of scattered particles across both frames.
  • Understanding of quantum field theory (QFT) principles
  • Familiarity with differential cross sections and scattering processes
  • Knowledge of frame transformations in particle physics
  • Experience with matrix elements in particle interactions
  • Study the derivation of differential cross sections in various frames
  • Learn about the implications of the infinite mass limit in scattering theory
  • Explore the relationship between |M|² and differential cross sections in QFT
  • Investigate the conservation laws applicable in particle collisions
Particle physicists, graduate students in theoretical physics, and researchers working on scattering processes and frame transformations in quantum field theory.
bnado
I have the following process: two ingoing particles, a photon hitting a nucleus, and two outgoing particles, the nucleus and a pion. I have computed |M|2 and the differential cross section in the center of mass frame dσ/dΩCM; I now have to go into the lab frame, where the nucleus is initially at rest, and consider the limit of a infinite massive nucleus MN→∞, and compute dσ/dΩlab.
Is there a general procedure to go from the first to the second? I first wrote dσ/dt and then multiplied it for a rather complicated expression that I found on a book to obtain dσ/dΩlab. However, taking the infinite massive nucleus limit, the result I get is not what I'm supposed to.
you should involve the fact
(dσ/dΩ')lab dΩ'=(dσ/dΩ)CM dΩ,which exploits the fact that the number of scattered particles passing through a cross section is same in both frames.
