QM:Expectation values and calculating probabilities
  • Thread starter Thread starter Wavefunction
    Probabilities
7 replies · 3K views
Wavefunction
An operator [itex]\mathbf{A}[/itex], corresponding to a physical quantity [itex]\alpha[/itex], has two normalized eigenfunctions [itex]\psi_1(x)\quad \text{and}\quad \psi_2(x)[/itex], with eigenvalues [itex]a_1 \quad\text{and}\quad a_2[/itex]. An operator [itex]\mathbf{B}[/itex], corresponding to another physical quantity [itex]\beta[/itex], has normalized eigenfunctions [itex]\phi_1(x)\quad \text{and}\quad \phi_2(x)[/itex], with eigenvalues [itex]b_1 \quad\text{and}\quad b_2[/itex]. [itex]\alpha[/itex] is measured and the value [itex]a_1[/itex] is obtained. If [itex]\beta[/itex] is then measured and then [itex]\alpha[/itex] again, show that the probability of obtaining [itex]a_1[/itex] a second time is [itex]\frac{97}{169}[/itex].
The eigenfunctions are related via:
[itex]\psi_1 = \frac{(2 \phi_1+3 \phi_2)}{\sqrt{13}}[/itex]
[itex]\psi_2 = \frac{(3 \phi_1-2 \phi_2)}{\sqrt{13}}[/itex]
Okay now I know I can represent [itex]|\psi\rangle[/itex] by:
[itex]|\psi\rangle = \frac{1}{\sqrt{13}}\begin{pmatrix}2&3\\3&-2\end{pmatrix}|\phi\rangle[/itex]
I also know that initially:
[itex]\mathbf{A}|\psi\rangle = a_1|\psi\rangle = \frac{a_1}{\sqrt{13}}\begin{pmatrix}2&3\\3&-2\end{pmatrix}|\phi\rangle[/itex] which I can then bra through by [itex]\langle \psi|[/itex] in order to get [itex]a_1 \langle \psi |\psi \rangle[/itex]
Here's where I'm stuck, but I think maybe I should repeat the above process with the respective operators to get something like [itex]\langle\mathbf{A}_{\alpha}\rangle \langle\mathbf{B}_{\beta}\rangle \langle\mathbf{A}_{\alpha}\rangle[/itex]
However, I'm unsure because I'm not very familiar with QM and I'm trying to prepare for the class before it begins this fall. Thanks for your help everyone.
It's a lot simpler than that -- I suspect you're over-thinking the problem.
I'm not sure how much I should give away in a first response, so I'll just offer an initial hint:
What is the probability that a state prepared in state ##\psi_i## will be detected as state ##\phi_j## ?
In other words, what is ##P(\phi_j|\psi_i)## (which is read as "probability of ##\phi_j##, given ##\psi_i##) ?
BTW, which textbook(s) are you working from? If you have Ballentine, then you might be able to deduce the answer to my question from his eq(2.28).
Well the text I have is Modern Quantum Mechanics 2nd Edition by J.J. Sakurai; however, I'm just picking random problems from different sources to get a feel for QM. This particular problem is from here: http://farside.ph.utexas.edu/teaching/qmech/Quantum/node44.html
In regards to the problem:[itex]P(\phi_j|\psi_i) = |\langle \phi_j|\psi_i\rangle|^2[/itex] correct? So then the probability of measuring [itex]b_1[/itex] when the system is in the state [itex]\psi_1[/itex] is [itex]|\langle \phi_1|\psi_1\rangle|^2=\frac{4}{13}[/itex]
Correct, so having measured ##b_1##, the system is now in the state ##\phi_1##. Then a third measurement is made, this time for A. What is the probability that, for your system in the state ##\phi_1##, that you measure ##a_1##?
Ah okay that would be [itex]|\langle \psi_1|\phi_1\rangle|^2 =\frac{4}{13}[/itex]
Correct, can you finish the problem?
I think so because I think now I need to multiply the two probabilities together to get [itex]\frac{16}{169}[/itex] Then I need to repeat the process for the state [itex]\phi_2[/itex]:
[itex]|\langle \phi_2|\psi_1\rangle|^2 = \frac{9}{13}[/itex]
Measuring [itex]\mathbf{A}[/itex] again:
[itex]|\langle \psi_1|\phi_2\rangle|^2 = \frac{9}{13}[/itex]
Multiplying together: [itex]\frac{81}{169}[/itex]
Now adding the two together yields [itex]\frac{16+81}{169} = \frac{97}{169}[/itex]
Yes, looks fine.
