[QM] Two-Particle Systems: overlapping/non-overlapping wavefunctions
2 replies · 3K views · last reply
WeiShan Ng
Textbook page titled Case 2: Identical particles, showing Equations 5.16 to 5.22 for expectation values of x1 squared, x2 squared and x1x2 with the cross terms boxed in red, plus the definition of the matrix element <x>ab.
Hi, I was reading Griffiths and stumble upon some questions. This is from 5.1.2 Exchange Forces. The section is trying to work out the square of the separation distance between two particles, $$\langle (x_1 - x_2)^2 \rangle = \langle x_1^2 \rangle + \langle x_2^2 \rangle - 2 \langle x_1 x_2 \rangle$$
My confusion came when
$$\int x_1 \psi_a (x_1)^* \psi_b (x_1) dx_1 \, \int x_2 \psi_b(x_2)^* \psi_a(x_2) dx_2 = \langle x \rangle _{ab} \langle x \rangle _{ba}$$ I don't get why there are ##\langle x \rangle _{ab}## and ##\langle x \rangle _{ba}## here , won't the $$\int x_2 \psi_b(x_2)^* \psi_a(x_2) dx_2=\int x_1 \psi_a (x_1)^* \psi_b (x_1) dx_1=0??$$ since both ##\psi_a## and ##\psi_b## are orthogonal to each other?
And in the next paragraph the text says
Notice that ##\langle x \rangle _{ab} ## vanishes unless the two wavefunctions actually overlap [if ##\psi_a(x)## is zero wherever ##\psi_b(x)## is nonzero, the integral in Equation 5.20 is zero] So if ##\psi_a## represents an electron in an atom in Chicago, and ##\psi_b## represents an electron in an atom in Seattle, it's not going to make any difference whether you antisymmetrize the wave function or not. As a practical matter, therefore, it's okay to pretend that electrons with nonoverlapping wave functions are distinguishable.
What is the meaning of "overlap" here? Based on the text given I assume it means both particles are "at the same position", i.e. ##x_1=x_2##. And how does an overlapping and non-overlapping wavefunction look like?
  • Textbook page titled Case 2: Identical particles, showing Equations 5.16 to 5.22 for expectation values of x1 squared, x2 squared and x1x2 with the cross terms boxed in red, plus the definition of the matrix element <x>ab.
This picture may answer your question "how does an overlapping and non-overlapping wavefunction look like?"
  • Two diagrams of wavefunctions phi1 and phi2 centred at separate points. Top: the two peaks overlap and the product phi1 phi2 is non-zero in the shared region. Bottom: the peaks do not overlap and phi1 phi2 is approximately zero everywhere.
Thank you!
