Quadratic - Completing the square
In summary, the conversation discusses solving an equation using factoring and completing the square methods. The first problem is solved using factoring, while the second problem is solved by completing the square. The correct answers are calculated and the conversation also includes a discussion about finding an approximate value of the roots.
thomas49th
655
Need to solve
2x² + 5x + 3 = 0
at² + bt + c = 0
so a = 2, b = 5, c = 3
a x c = 6
a + c = 5
so ned to find somthing that times to make 6 and add to make 5. That is 2, 3
2x² + 2x + 3x + 3
2x (x + 1) + 3(x + 1)
(2x + 3)(x + 1) = 0
so x is either
x = 3/2 = -1.5 or x = -1
Are those answers correct?
If so how would I go about solving this question
A solution to the equation [tex]x^{5} - 4x^{3} = 455[/tex] lies between x = 3.6 and x = 3.8. Find the solution to 2 decimal places.
So should change it = 0 by -455 so i get
[tex]x^{5} - 4x^{3} -455 = 0[/tex]
now where do i go?
Thx
Your answers are correct. However, your thread title says "completing the square" - you've solved by factoring (which is easier for this particular problem.
Personally, I teach completing the square this way:
2x^2 + 5x + 3 = 0
Get rid of the 3; it's just in the way.
2x^2 + 5x = -3
now factor out any coefficients on the x^2.
2(x^2 + 5/2x ) = -3
Then, add (inside the parenthesis) half of the middle term squared.
Since you have to add the same amount to both sides, add to the right side as well; note: whatever you add inside the parenthesis will be multiplied by 2. Thus:
2(x^2 +5/2 x + 25/16)= -3 + 25/8
Factor (it'll always be half the middle term again)
2(x+5/4)^2 = 1/8
divide by 2
(x+5/4)^2 = 1/16
take the +/- square root
x+5/4 = +/- 1/4
subtract 5/4, and you have your same answers.
For your second problem, there are several ways to solve it, to get it correct to 2 decimal places... what methods have you learned? Show me how you would apply one of those methods and I or someone else can show you where you're making a mistake (or let you know if you're on the right track.)
[tex]x^{5} - 4x^{3} -455 =(x^{2} - 4x)^{3} - 64 - 455 [/tex]
is that right?
I have no idea what you are doing. But (x2)3 is x6 not x5 so that can't be right!
I think I've got it
x³(x²-4) can be factorised even fruther to
x³(x+2)(x-2)
that means the equation can be x = -2, x = 2 or x=0
thomas49th said:
I think I've got it
x³(x²-4) can be factorised even further to
x³(x+2)(x-2)
This would be true if the equation was [tex]x^{5} - 4x^{3} = 0[/tex], but your equation is [tex]x^{5} - 4x^{3} = 455[/tex]. Since you're looking for an approximate value of the roots, you are not looking to solve this by factorisation.
drpizza hints at this in post #2.
1. What is completing the square in quadratic equations?
Completing the square is a method used to rewrite a quadratic equation in the form of (x + a)^2 + b, where a and b are constants. This form is also known as "vertex form" and is useful for finding the vertex of a parabola.
2. Why is completing the square useful?
Completing the square allows us to easily find the vertex and other important information about a parabola, such as the minimum or maximum value. It also helps in solving quadratic equations and graphing parabolas.
3. How do you complete the square?
To complete the square, follow these steps:
  1. Make sure the coefficient of the x^2 term is 1. If not, factor it out.
  2. Take half of the coefficient of the x term and square it.
  3. Add this value to both sides of the equation.
  4. Factor the perfect square trinomial on the left side of the equation.
  5. Simplify the right side of the equation, if necessary.
4. What is the purpose of completing the square?
Completing the square allows us to manipulate a quadratic equation into a more convenient form for solving and graphing. It also helps us find the vertex, which is a key point on the parabola.
5. Can completing the square be used on any quadratic equation?
Yes, completing the square can be used on any quadratic equation, as long as the coefficient of the x^2 term is 1. If the coefficient is not 1, we can still use completing the square, but it involves an extra step of factoring out the coefficient first.
  • Precalculus Mathematics Homework Help
