Qualitative question about the Stark effect
  • Thread starter Thread starter Clara Chung
    Stark effect
The discussion revolves around the Stark effect, specifically in the context of hydrogen and Rydberg atoms. Participants are exploring the number of sublevels for different principal quantum numbers (n=7, 8, and 9) and the implications of perturbation theory on these levels.
  • Participants question the reasoning behind the limited number of sublevels for higher n values and discuss the implications of selection rules on state mixing. There are inquiries about the nature of matrix elements in perturbation theory and how they relate to degeneracy.
The conversation is ongoing, with participants offering insights into the complexity of the problem. Some guidance has been provided regarding the nature of states and their connections, but there is no clear consensus on the overall understanding of the topic.
Participants note the lack of familiarity with degenerate perturbation theory, which is central to the problem being discussed. There is also mention of the problem's relevance to an introductory atomic physics exam.
Clara Chung
Attached below
Attached below
242121
For e ii) The answer is
242122
Why are there only 4 sublevels?
We haven't learned about degenerate perturbation theory, the only thing mention in lecture is
242123
which I don't understand so I only memorize the good eigenfunctions for n=2. Could you explain why there are still only 4 sublevels for n=7 and 8?
You do understand the Hydrogen atom Stark effect and not the Rydberg atom? (I'm not sure what you need here)...
For n=7 and n=8 there will be n^2 eigenfunction... if the states that will be mix are the states that satisfy the selection rules... i.e. delta l=+-1 and delta m=0, there will be so many... not only the two eigenstates in the hydrogen atom...?
He is talking about the n=9 Rydberg states only. Within this are the allowed states L=0,1,...,8 each with multiplicity 2L+1. Only the highest angular momentum states are "far enough away" from the "nucleus/inner electron complex" to be approximately degenerate. So we are down to L=7,8. So how will this subset be affected by perturbation?
If only L=7,8 are approximately degenerate... There are still many levels that can be mixed... Like l=7, ml=0,1,2,3,4,5,6,7 with l=8, ml=1,2,3,4,5,6,7...??
Yes all those states (let's be precise ml=0, ±1,..., ±L for L=7,8). But what about the (mixing) matrix elements. Are some zero? Are some the same size? This is not an easy exercise...but it is good. Clearly some levels will still be degenerate.
How to know whether they have the same size? :(
There are two states you know don't connect (create any off diagonal elements). What are they?
You say you have not had degenerate perturbation theory...why are you (we) looking at this problem? It is not obvious to me exactly how it simplifies completely as advertised.
Thank you for your help.. This appears in an exam of an introductory course on atomic physics... I guess I will leave it...
Perhaps someone else on the Forum sees the route to the requested solution. Also you can keep this problem in your head and, as you learn more, re-examine the possible solutions. To have such mental touchstones is not a bad thing.
