Qualitative question about the Stark effect
  • Thread starter Thread starter Clara Chung
    Stark effect
The discussion centers on the Stark effect and the confusion surrounding the number of sublevels for quantum states n=7 and n=8. Participants clarify that while there are n^2 eigenfunctions, only specific states that satisfy selection rules will mix, leading to a limited number of effective sublevels. The conversation highlights the complexity of degenerate perturbation theory and its implications for understanding these states. There is acknowledgment of the challenge in determining the mixing matrix elements and their significance in the context of perturbation. The thread concludes with encouragement to revisit these concepts as knowledge deepens, emphasizing the importance of foundational understanding in atomic physics.
Clara Chung
Attached below
Attached below
242121
For e ii) The answer is
242122
Why are there only 4 sublevels?
We haven't learned about degenerate perturbation theory, the only thing mention in lecture is
242123
which I don't understand so I only memorize the good eigenfunctions for n=2. Could you explain why there are still only 4 sublevels for n=7 and 8?
You do understand the Hydrogen atom Stark effect and not the Rydberg atom? (I'm not sure what you need here)...
Likes Clara Chung
For n=7 and n=8 there will be n^2 eigenfunction... if the states that will be mix are the states that satisfy the selection rules... i.e. delta l=+-1 and delta m=0, there will be so many... not only the two eigenstates in the hydrogen atom...?
He is talking about the n=9 Rydberg states only. Within this are the allowed states L=0,1,...,8 each with multiplicity 2L+1. Only the highest angular momentum states are "far enough away" from the "nucleus/inner electron complex" to be approximately degenerate. So we are down to L=7,8. So how will this subset be affected by perturbation?
Likes Clara Chung
If only L=7,8 are approximately degenerate... There are still many levels that can be mixed... Like l=7, ml=0,1,2,3,4,5,6,7 with l=8, ml=1,2,3,4,5,6,7...??
Yes all those states (let's be precise ml=0, ±1,..., ±L for L=7,8). But what about the (mixing) matrix elements. Are some zero? Are some the same size? This is not an easy exercise...but it is good. Clearly some levels will still be degenerate.
How to know whether they have the same size? :(
There are two states you know don't connect (create any off diagonal elements). What are they?
You say you have not had degenerate perturbation theory...why are you (we) looking at this problem? It is not obvious to me exactly how it simplifies completely as advertised.
Likes Clara Chung
Thank you for your help.. This appears in an exam of an introductory course on atomic physics... I guess I will leave it...
Perhaps someone else on the Forum sees the route to the requested solution. Also you can keep this problem in your head and, as you learn more, re-examine the possible solutions. To have such mental touchstones is not a bad thing.
