Quality Latex editors for Windows?
4 replies · 6K views
Homework Helper
Hi, doing some research for free Latex editors for Windows 10. I did an online search but would like to know the experiences of people with Latex editors, if any.
Thanks.
I'm perfectly fine with TeXStudio
https://texstudio.org/
Of course in addition to AutoHotKey which speeds my typing by individually set shortcuts. I find it so convenient, that I even type what I would formerly had written on paper. I filled a dozen pages over the weekend with a lot of examples, many of them calculated while typing.
I use TexMaker.
If you are looking for an IDE at the level of Intellij IDEA, then unfortunately there isn't one for LaTeX. However, TexStudio or TexMaker combined with AHK as suggested by @fresh_42 is fine.
I use TeXnic Center https://www.texniccenter.org/
This is a standalone pop up which has optional rows of menu icons across the top (you can turn on/off the ones you want etc).
You have to have an underlying TeX or LaTeX distribution also separately installed, and the one I use is called MikTeX https://miktex.org/
steps
1) install latest MikTeX on your Windows 10 or whatever version
2) install TeXnic Center on your Windows 10 or whatever version
Now, you click on Open New file and you get a blank which you fill in with your own LaTeX commands, and you hit LaTeX->PDF across the top row (among others like LaTeX->PS, or DVI, ...). Make sure that you do NOT have open the same name PDF in your PDF reader or else the TeXnic Center build will crash. But if you delete the same name PDF in your PDF reader (but keep something else open in that PDF reader so you don't have to start a new PDF reader each time, and if you have a PDF reader open in other Windows10 desktops, then if your LaTeX is in Desktop 2 but your only other open PDF reader is in Desktop 3, then when you try to view the new PDF you just compiled in 2 it will open in Desktop 3 PDF reader. This is solved if you have a PDF reader open in 2 with a different PDF file in 2. This is a Windows10 feature they don't see as a bug yet.)
I use MikTex + WinEdt and very happy about it.
Eugene.
