Quantum Mechanics - Finding expectation value
The discussion focuses on finding the expectation value of position as a function of time in quantum mechanics. The initial approach involved integrating the wave function products but led to a time-independent result due to incorrect application of the formula. After realizing the mistake, the correct formula was applied, incorporating the position variable into the integral. The final expression indicates that the expectation value will vary with time, provided that a specific integral does not equal zero. The participants emphasize the importance of correctly setting up the integrals to capture the time-dependent behavior of the expectation value.
Kyle91
Find the expectation value of position as a function of time.
This is in the latter half of a multi-part question, previously we were given that:
Eqn 1: Ψ(x, t) = A(ψ1(x)e−iE1t/h¯ + iψ2(x)e−iE2t/h¯)
and in an even earlier part:
Eqn 2: ψn(x) = sqrt(2/L)sin(n*pi*x/L)
Note: h¯ = hbar
As you can tell, I'm not too awesome at formatting on here so I'm going to quickly explain my method.
I said:
<x> = Integral from 0 to L of Ψ*(x, t)Ψ(x, t) dx
So I told wolframalpha (we're allowed to use it) to simplify Eqn 1, before subbing in Eqn 2.
This gave me:
Eqn 3: -2(ψ1ψ2sin(t(E1-E2)/h¯) + ψ12 + ψ22
I then subbed in Eqn 2 into Eqn 3 and integrated.
No matter how many times I do this I always end up with a bunch of sines. These sines are all something like sin(n*pi/L) so when I sub in the limits of integration they become sin(n*pi) or sin(0), both of which are 0!
This means that I'm just left with an answer of 2, which is not time dependent.
Can anyone see where I've gone wrong?
Okay so I just found out I've had the formula wrong from the start. FML.
It's now:
<x> = Integral from 0 to L of Ψ*(x, t)xΨ(x, t) dx
However, this still didn't help me.
I'm now left with:
A2(L - L/(2pi2) + L/(4pi2) + L/(16pi2))
And I am thoroughly sick of this.
What happened to the factor of \sin\left[\frac{(E_1-E_2)t}{\hbar}\right]?
After you multiply the integrand out, you should have
\begin{align*}
\langle x \rangle &= A^2\int_0^L \left(x\psi_1^2(x) + x\psi_2^2(x) - 2x\psi_1(x)\psi_2(x) \sin [(E_1-E_2)t/\hbar]\right)\,dx \\
&= A^2\left(\int_0^L x\psi_1^2(x)\,dx + \int_0^L x\psi_2^2(x)\,dx - 2\sin [(E_1-E_2)t/\hbar]\int_0^L x\psi_1(x)\psi_2(x)\,dx\right)
\end{align*}
As long as that last integral isn't 0, the expectation value will vary with time.
I love you vela. Thank you so much.
  • · Replies 18 ·
