Question about a circuit using a 555 timer
When the potentiometer in the 555 timer circuit is turned down to zero resistance, the capacitor discharges rapidly, resulting in a mostly high output with a very brief low time. If resistance is completely eliminated, the output could remain high continuously, risking damage to the internal transistor responsible for discharging the capacitor, particularly with larger electrolytic capacitors. A user reported issues with their 555 timer not pulsing correctly, despite checking connections and configurations for an astable mode at 6.5 Hz. Initially, the timer overheated when connected improperly, but after adjusting the resistance, it operated at 5V without overheating. The user suspects either a damaged timer or incorrect pin connections, prompting a request for further troubleshooting assistance.
line2
Here's the drawn circuit: http://imgur.com/DGo9M.png
R1 is 10k Ohm resistor
Pot is a 100k Ohm potentiometer
C is 1.0uF Electrolytic Capacitor
My question is, what happens when the potentiometer is turned down to 0 resistance? Would the circuit fry?
thanks
Pin 7 discharges the capacitor after it has fully charged. So, if you made the resistor almost zero, the capacitor would discharge very quickly.
This produces an output that is mostly high but with a very short low time.
If you could make the resistance zero, the output would stay high all the time but there is a risk that the transistor that discharges the capacitor (inside the chip) could get damaged, especially if a large electrolytic capacitor was used.
problem with my HA17 555 timer
i recently bought my 555 timer and i simply can't get it to pulse. I flick on the switch and i get my buzzer to work that is connected to the output but i don't hear it turn off and on. I set my configuration as astable 6.5 Hz. i checked all my connections and everything seems right. However during my first run, i connected my timer circuit parallel to 1k that was instead of two 1k connected with source along with 30 ohms the circuit (that gave off 9v 8mA). And during my first 2 runs my timer was heating up really fast. After adding another 1k to the source (as the pic) i was able to get 5V and then it didn't heat up. I even checked my simulation with multisim and despite of that i don't get any pulse (the buzzer jus keeps going and no beep).
I am thinking its either i burned my timer or i got the pinning wrong. Check both my image files to see i am doing anything wrong. Btw 9V with 30 ohms in series depicts my adaptor that gives off 9V with 300 mA
Download file from link below.
http://squadinvenire.uuuq.com/555_timer.rar
I am trying to understand how transferring electric from the powerplant to my house is more effective using high voltage. The suggested explanation that the current is equal to the power supply divided by the voltage, and hence higher voltage leads to lower current and as a result to a lower power loss on the conductives is very confusing me. I know that the current is determined by the voltage and the resistance, and not by a power capability - which defines a limit to the allowable...
  • · Replies 38 ·
23K
  • · Replies 29 ·
9K
11K
  • · Replies 107 ·
30K
