Question about a horizontal sundial
  • Context: High School
  • Thread starter Thread starter Luxdot
    Horizontal
The discussion revolves around the design and functionality of horizontal sundials, specifically focusing on the relationship between the height and angle of the gnomon and the geographical location of the user, particularly latitude. Participants explore how these factors influence the accuracy of timekeeping with sundials.
  • Some participants propose that the height of the gnomon in a horizontal sundial is dependent on latitude, as it affects how high the sun appears in the sky.
  • Others argue that altitude does not influence the design of the sundial, emphasizing that latitude is the critical factor.
  • A participant suggests that the gnomon's sloped section must be parallel to the Earth's rotation axis, which would mean its angle corresponds to the user's latitude.
  • There is a question about whether the term "height" used by the original poster refers to the angle of the gnomon or its physical length.
  • One participant mentions the 'Equation of Time' as a consideration for setting the gnomon, indicating that it may help in achieving accurate readings.
  • Another participant clarifies that aligning the gnomon with the Earth's rotation axis allows for a consistent shadow movement, although any angle could technically be used.
  • Concerns are raised about the consequences of using an incorrect angle for the gnomon, suggesting that it could lead to seasonal errors in timekeeping.
  • Participants note that historical perspectives on timekeeping have shifted, with sundials once being the standard for accurate time before the advent of mechanical clocks.
Participants express differing views on the relevance of altitude versus latitude in sundial design. While there is some agreement on the importance of aligning the gnomon with the Earth's rotation axis, the discussion remains unresolved regarding the implications of angle adjustments and the influence of the Equation of Time.
Limitations include potential misunderstandings of terminology (e.g., "height" vs. "angle") and the complexities introduced by factors such as time zone differences and the elliptical nature of Earth's orbit.
Luxdot
TL;DR
How does the height of the gnomon affect the sundial
I am curious how the height of the gnomon in a horizontal sundial is dependent on your location. Why does it need to be different high depending on where you are? Does it have to do with how high the sun is in the sky depending on the latitude you are on?
Astronomy news on Phys.org
I have not heard that altitude of the place matters the design of sundial. The latitude matters.
OP said height of the gnomon.
Isn't it just that you need the sloped bit of the gnomon to be parallel to the rotation axis of the Earth? Thus it makes an angle with the floor equal to your latitude.
Is angle what the OP means by "height"? I assumed the OP meant length.
But your suggestion makes much more sense.
See the fourth bullet in the diagram you posted.
Depends on whether the OP knows that, of course. Let's see what they say.
Would the 'Equation of Time' be of any help to Luxdot?
https://en.wikipedia.org/wiki/Equation_of_time
I ask because when I was considering putting a sundial in my garden, a member of the local astronomy club advised me to employ this equation when setting the gnomon in relation to the sun.
Thank you.
Cerenkov.
Yes, I am talking about the angle! So this has to do with the rotational axis of the earth?
Yes. If you align the style parallel to the Earth's rotation axis then the movement of the shadow is a constant rate. You can use any angle you like, in fact, but the non-uniform motion makes it harder to read the dial when the shadow isn't pointing exactly at a marking.
So what would happen if the angle is decreased? I.e. smaller than the correct one for that latitude?
I'm assuming you're asking about the vertical angle above the horizontal plane.
If that angle doesn't match the latitude, unnecessary errors will be introduced in different seasons. If the angle is wrong, and you trace out the hour lines in the spring or fall, they'll be a little in error in the summer (either too "squished up" up or too spread out) and in error in the other direction in the winter. If you want to minimize this seasonal error, ensure the vertical angle matches the latitude.
[Edit: and if you have the option, you should trace out the hour lines based on your latitude.]
There will still be other sources of error such as time zone considerations, Daylight Saving Time (if that applies in your location), and the fact that Earth's orbit around the sun is not perfectly circular.
That last one is the curious one. A century or so ago, the errors caused by Earth's orbit being slightly elliptical wouldn't be errors at all. The sundial was the "correct" timepiece. If a clock said differently it was the clock's fault. The clock was in error. The sun's position in the sky was the correct source of time.
Things have changed since then, but the change happened not too long ago. On the grand scheme of human history, it was only quite recently that we changed paradigms, and started using [non-solar based] clocks to keep official time.
  • · Replies 16 ·
14K
  • · Replies 0 ·
