Question about a Square Light Clock
  • Context: Undergrad
  • Thread starter Thread starter south
The discussion revolves around the concept of a square light clock, specifically examining whether the unit of time defined by the clock's operation is dependent on speed. The scope includes theoretical considerations of time dilation, relativistic effects, and the implications of different observers measuring time in relation to the clock.
  • Some participants assert that all clocks, including the square light clock, depend on speed in the same way.
  • Others question the reference frame for speed, suggesting that two identical light clocks moving relative to each other would observe time dilation and length contraction.
  • A participant introduces a scenario with two light clocks fixed relative to each other, arguing that if they did not maintain the same tick rate, it would lead to contradictory results for observers in motion.
  • Another participant presents an analysis indicating that the square light clock must time dilate similarly to other clocks, implying a need for an absolute sense of rest if this were not the case.
  • Mathematical expressions are provided to describe length contraction and the timing of the square light clock, suggesting a relationship between speed and the clock's operation.
  • Concerns are raised about the implications of differing tick rates leading to a violation of the first postulate of relativity.
Participants express differing views on the dependence of the clock's time measurement on speed, with no consensus reached. Some argue for a uniform behavior of clocks under relativistic conditions, while others highlight the complexities introduced by different reference frames.
The discussion includes assumptions about the behavior of light clocks under relativistic conditions and the implications of time dilation, which may not be universally agreed upon. The mathematical derivations presented rely on specific conditions that may not be fully explored.
south
TL;DR
Light clock with 4 plates
At each vertex of a square, there is a mirror with its plane perpendicular to the diagonal containing the vertex. The reflecting side faces the center of the square.
A beam of light is successively reflected off each of the mirrors, such that it travels around a square circuit. Each time it completes a circuit, we count a unit of time.
Does the unit of time defined in this way depend on speed?
Yes, all clocks depend on speed in the same way.
Speed relative to what?
Imagine two of these light clocks, identically constructed and moving relative to one another. Both will find that the other one is running slow (and length-contracted in the direction of motion, and Terrell-rotated).
"Speed" of what?
That clock you've designed and constructed in your lab is currently moving relativistically (as observed by someone in, say, Andromeda).
Do you observe your own clock in your lab behaving weirdly?
Consider this: Instead of just that light clock, you have second standard Light clock next to it, with the mirrors spaced apart such that the back and forth trip is the same length as the square light clock path. These clocks are fixed relative to each other. Anyone at rest with respect to them would see the two clocks ticking in perfect sync. Now add an observer who in in motion with respect to both clocks and measures the clocks undergoing time dilation. If the two clocks didn't maintain the same tick rate, they'd go out of sync and you'd have the two observers recording two physically contradicting results.
south said:
TL;DR Summary: Light clock with 4 plates
@Janus' analysis shows that this clock (and indeed any other) must time dilate the same way, or else there must be an absolute sense of rest. No further analysis is needed. However, the analysis from first principles of this clock is a trivial extension to the usual light clock as long as velocity is parallel to one side (it's messier for a velocity that is not parallel to a side, but still not particularly difficult). You should carry it out (edit: note that there's a completely maths-free way of doing it if you think a bit). The only thing to remember is the length contraction factor of the side parallel to the motion.
Length contraction: ##a' = a\sqrt{1-v^2/c^2}##
##T' = {a \over \sqrt{c^2-v^2}} + {a' \over c-v} + {a \over \sqrt{c^2-v^2}} + {a' \over c+v}##
##T' = {a \over \sqrt{c^2-v^2}} + {a' (c+v)\over c^2-v^2} + {a \over \sqrt{c^2-v^2}} + {a' (c-v)\over c^2-v^2}={4a \over c}\gamma##
You'd have a way to distinguish between a state of rest and a state of uniform motion, violating the 1st Postulate.
Thanks to the persons which help me. Best regards.
  • · Replies 33 ·
  • · Replies 93 ·
  • · Replies 42 ·
  • · Replies 88 ·
  • · Replies 33 ·
  • · Replies 25 ·
