Question about accelerator physics
In accelerator physics, the mapping matrix M(s+L|s) is utilized to analyze the motion of particles. The discussion reveals that after one turn, the values of (x, x') change, indicating that the particle's position and angle are not constant, leading to non-closed trajectories. This phenomenon occurs due to inherent imperfections in components, causing unaccounted deviations that accumulate over time. Consequently, maintaining closed trajectories is impractical, as they result in rapid loss of particles.
  • Understanding of mapping matrices in accelerator physics
  • Familiarity with particle motion dynamics
  • Knowledge of trajectory analysis in classical physics
  • Basic concepts of deviation and error accumulation in physical systems
  • Research the implications of mapping matrices in particle accelerators
  • Study the effects of component imperfections on particle trajectories
  • Explore methods to mitigate deviation in accelerator physics
  • Investigate the mathematical models of closed and non-closed trajectories
Physicists, engineers, and researchers in accelerator physics, particularly those focused on particle motion analysis and trajectory optimization.
Ruihu Zhu
In accelerator physics, mapping matrix is often used to describe particle's motion.For a given one turn mapping matrix,namely M(s+L|s) ,and initial (x,x').After matrix multiplication, I find the value of (x,x') changes which means particle's position and angle changes at the same s after one turn mapping.This shows the trajectory of this particle is not closed.I can't understand why this happens.
I moved the thread to classical physics.
That's how it has to be. A closed trajectory might work in mathematics but not in reality. Components are never perfect, so particles will get some unaccounted deviation. With a closed trajectory after one turn they will always get the same deviation which accumulates, and they will get lost quickly. Even a closed trajectory after 2-5 turns should be avoided.
Likes jbriggs444
  • · Replies 18 ·
  • · Replies 43 ·
11K
