Question about calculating work done
  • Thread starter Thread starter mahaju
    Work Work done
Work is defined in physics as force multiplied by displacement, meaning that if there is no movement, such as pushing against a wall, no work is done despite energy being expended. While energy is used when pushing against a wall, it does not transfer energy to the wall, resulting in zero mechanical work. This distinction is crucial, as energy expenditure does not equate to work in the physics sense. The discussion also touches on the concept of efficiency, highlighting that energy input often does not equal work output due to losses. Ultimately, while energy is consumed, it does not always imply that work, in the strict physical definition, is being performed.
mahaju
Hi
We all know that work done corresponds to energy used and calculated as force*distance
So if we are pushing against a wall, it does not count as work done, as there is no motion
However, aren't we still wasting energy when we are pushing against a wall? Since a certain amount of energy is being expended shouldn't it count as work being done?
For example, if we pass current through a resistor, there is no motion, still energy is used up as heat for the resistor. Shouldn't this energy expended be counted as some equivalent work being done?
Thanks
mahaju said:
Hi
Thanks
SHort answer - NO.
Work is Force*displacement [dot product of the two vectors] The dot product means that if the two vectors [force and displacement] at perpendicular, then no Work is done.
Note that if you swing a 10kg mass in a circle, the force you apply [centripetal Force] is at all times perpendicular to the motion - especially if you use a string - so no Work is done there either. You will certainly get tired, but the circling mass will not gain Kinetic Energy: is travels at constant speed in a circle.
Many people go to work every morning, then come home every evening, but, depending on their field of employment, may not do any Work at all - in the sense that we define it in Physics.
Notice that I called it Work, not work [capital letter].
so we should say that work requires energy, but use of energy does not always imply work
right?
Mechanical work is not the only way to expend energy, but your muscles are probably doing work. They are still contracting (so the cells are moving) and they are creating heat which is moving particles.
I think that in modern physics the idea of energy trumps the idea of work. Usually "mechanical work" is what the macroscopic \int F\cdot\vec{dx} work is called. At a molecular and atomic level that definition becomes meaningless.
right?
If you define Work as macroscopic mechanical work (which is how my profs use it) then you are correct. I think the use of work to define energy is a historical artifact as well as a pedagogical tool. But I may be wrong.
right?
I note you have not referred to Work in your statement, merely work - which has far reaching "general-population" implications.
Remember; Work is ours, and has a very specific interpretation.
Work is spelled with a lower case "w", not Work; as this is a physics forum, I would assume most of the posters here know that when talking about work, the physics definition is implied.
mahaju said:
Hi
I believe Work represents the energy that is transferred through distance,not the energy is used.
In the case of pushing a wall although you use energy...you don't transfer energy to the wall hence you don't do Work.
The Work is differentiated from energy expenditure by the factor of efficiency(e=W/E).In wall pushing you have zero efficiency.
Thanks to everyone for the informative replys
Work is being done but not on the wall.The work is internal and due to the actions required of the muscles in order to do the pushing.
right?
Correct. Energy in doesn't usually equal work out due to losses: it is always less. You've just discovered the concept of efficiency.
