Understanding the Effects of Dielectrics on Capacitance: A Scientific Approach
The discussion focuses on the effects of inserting a dielectric into a capacitor that has been charged and disconnected from a battery. It is established that inserting a dielectric increases the capacitance (III is true), while the voltage across the capacitor will change (I is false) and the potential energy will also increase (II is false). The charge remains constant because the battery is not connected, preventing any additional charge flow.
  • Understanding of capacitor fundamentals and charging principles
  • Knowledge of dielectric materials and their effects on capacitance
  • Familiarity with Kirchhoff's Law and its application in circuits
  • Proficiency in using the equation for potential energy in capacitors: U = 0.5 * Q * deltaV
  • Study the relationship between capacitance and dielectric constant in detail
  • Learn about the implications of charge conservation in disconnected circuits
  • Explore the mathematical derivation of voltage changes when dielectrics are inserted
  • Investigate practical applications of capacitors with dielectrics in electronic circuits
Students studying electrical engineering, physics enthusiasts, and educators looking to deepen their understanding of capacitors and dielectrics in circuit theory.
RoboNerd
A capacitor, is fully charged by a battery. The battery is disconnected and a dielectric is inserted into the capacitor. Which of the following is true?
I. Voltage will stay the same
II. Potential energy of the capacitor will increase
III. capacitance will increase
I know that III is true as dielectrics by definition increase capacitance. How can I eliminate the other two to get the final answer of III only?
Thanks in advance.
Battery maintains constant voltage.Since it is removed voltage will change.
But there is no flow of charge.Using the relation between Charge ,Potential and capacitance and this information find change in voltage and potential energy.
Technically you don't need to "eliminate" the other choices as long as you are certain that a specific choice is correct in a multiple choice question.
But I) is wrong simply because inserting a dielectric changes the electric field E and it is V=Ed where d the (constant) distance between the plates.
II) you can answer it yourself, using the equation you wrote in OP and calculating how voltage will change (increase or decrease)? (Charge will remain the same (why?))
Charge will remain the same because the battery is not connected to the capacitor, so the battery can not pump out more charged particles in response to the insertion of the dielectric.
Why does a battery maintain constant voltage? And, I take it that there is no flow of charge because there is no potential difference caused by having a battery hooked up to the circuit?
Battery is like a pumping device. It pumps charge.When connected to a capacitor it pumps charge till steady state is achieved.In steady state when there is no flow of charge we can easily prove that potential difference across the capacitor is constant using Kirchoff's Law.
I wonder what have you been taught about the dielectric constant k:
1) A capacitor with dielectric of dielectric constant k, has capacitance ##C_k=kC_0## where ##C_0## the Capacitance with vacuum between its plates.
or
2) The electric field between the plates of a capacitor with dielectric k is ##E_k=\frac{E_0}{k}## where ##E_0## the electric field with vacuum between the plates.
1) A capacitor with dielectric of dielectric constant k, has capacitance Ck=kC0Ck=kC0C_k=kC_0 where C0C0C_0 the Capacitance with vacuum between its plates.
or
2) The electric field between the plates of a capacitor with dielectric k is Ek=E0kEk=E0kE_k=\frac{E_0}{k} where E0E0E_0 the electric field with vacuum between the plates.
yes, I know how a dielectric works. thank you.
I see how I should solve this problem. Thanks a lot everyone!
  • · Replies 17 ·
  • · Replies 21 ·
