Question about Complex Integrals
In summary: I don't actually know how to work that out. I think it might be something to do with the area of the curve C? But I'm totally lost at this point and would appreciate any help you can offer!In summary, the author is asking for help with integrals and is confused about what to do. The first part is where the semicircle is in the upper half of the imaginary plane and z=e^(itheta). The second part is where z changes but z*=e^(-itheta). The first part is where z*=e^(-itheta). The second part is where z=e^(itheta) and z*=cos(
Claire84
219
Hey there, I've just a quick question about numer 6 at the following link -
http://titus.phy.qub.ac.uk/group/Jorge/AMA203/assignments/ass03_7.pdf
I'm normally okay with integrals but I'm a bit rusty on them at the mo (I haven't done a proper integral since May/June time, ooops!) and I'm convinced I'm doing something wrong here. For the first part (where the semicircle is in the upper half of the imaginary plane), I've let z=e^(itheta) so z*= e^(-itheta). Then to change the variable I've done dz/dtheta and got ie^(itheta). Since it moves around the upper half from x=1 to x= -1, I thought this would be equivalent to it going from 0 to pi. So I've calculated the integral (bottom limit=0 and upper limit=pi) and got i(pi) out of it.
For the next one I wasn't sure if I was doing it right because it was going below the plane. I kept z=e^(itheta) since although the path was changing, I figured that since the angles we'd now be using would be negative, we could keep what looks like the same z as before. So I calculated it in the same way as the first part, except having my lower limit as 0 and my upper limit as -pi. In the end I got -i(pi) out of it.
Can anyone check if those are okay or not? I guess I got confused at first because I expected thm to be equal, but then I think that z* isn't analytic so this isn't necessarily the case. If anyone could shed any light on it I'd be really grateful. Thanks. :smile:
It does make sence, the fact that z* is not analytical => it depends on the path.
But that doesn't mean two different paths can't give the same integral!
Since both of these are on parts of the unit circle, convert to polar form:
z= re so on the unit circle, z= e= cos(θ)+ i sin(θ) and z* (am I correct that that is the complex conjugate of z?) = cos(θl)- i sin(θ).
The integral around the upper semi-circle is the integral of that from θ= 0 to θ= π and the integral around the lower semi-circle is the integral of that from θ= 0 to θ= -π.
I never said that :P. Of course they can, but if is not analytical, there must be some (open) path where the integral is not the same, right?
Yeah, I think that's the way I did it. I hope it's right anyway cos I handed it in before lunch today. :eek:
Thanks, btw. :smile:
Btw, while I'm in the mood for asking dumbo questions, we got our new h/work today and I'm a bit fuzzled by something. We're using he Darboux inequality to find out the maximum value of |f(z)| on C where C : |z| = 3 (the circle with radius 3). We need to know the length of C for this which I get to be 6pi just from using that the circumference of the circle is 2pir and r here is 3. However, if I wanted to work it out using an integral, I keep getting my answer to be zero!
I start by putting z=3e^(itheta) and then having that dz= 3ie^(itheta)dtheta. I know that the length of C is the integral over dz, so I tried integrating what I got for dz between 0 (lower limit) and 2pi (upper limit), and all I can get is 0. I'm totally baffled. I mean I think I can see what the obvious answer is, but I just want to show it with integration...
can you remind me of Darboux inequality pls?
Sure, although I don't know how to use the proper maths typing that you lot use (technophobe!).
It's given by | closed line integral of f(z) | <= ML . Or given in words (which might make a little more sense judging by my awful attempt to write that out properly), it's the modulus of the line integral of f(z) around the curve C, which is less than or equal to ML where M is the maximum value of |f(z)| on C and L is the length of C. So from the h/work I need to work out the values of M and L. At least I think that's what we've got to do. Here's the homework sheet it's taken from -
http://titus.phy.qub.ac.uk/group/Jorge/AMA203/assignments/ass03_8.pdf
and it's question 2.
I'm also presuming that to work out M which is the maximum value of the modulus of f(z) on C we've to work out df/dz and set it equal to zero. Or something like that! I'm hopign I can do that okay, but I'm just confused about working out M using integrals, since I'm getting zero here where I should be getting 6pi.
So? what's your problem? You know the length of the curve right? The only thing you need to do is find the maximum of the norm over the curve.
Yeah, I know that I know the length of the curve, but I want to show this length by integration and I don't know why it won't work. I'm guessing it's because the function I'm integrating is analytic but I'm not sure.
The thing is, when you're finding the maximum for saya function such as f(z)= 1/((1+z^2)^3) then how can you do the differential to find the maximum? All you'll get is z=0 will you not (which doesn't lie on C)? I mean I've looked further on in my notes that we can write the modulus of the maximum of this f(z) as being less than or equal to the modulus of 1/((1-R^2)^3) since R is so much larger than 1 and z=Re^itheta... I'm just not sure where all that comes from as in how you can change the modulus to be like that, like how can you be sure that's the maximum?...). I'm okay if we can set the differential equal to zero but what about if it results in this?
Integrating dz over a contour does not give the length of the contour. You want to integrate |dz| over the contour (notation varies, |dz|=ds, where s is arclength). If [tex]\gamma(t)[/tex] from [a,b] is a parameterization of your contour, then
[tex]\int_{\gamma}|dz|=\int_{a}^{b}|\gamma '(t)|dt[/tex]
You can try this on your circle, but it won't be a very exciting computation.
To maximize |f(z)| on your circle, we can look to minimize [tex]|1+9e^{2i\theta}|[/tex] (after setting [tex]z=e^{i\theta}[/tex]). This is the same as minimizing [tex]|1+9e^{2i\theta}|^2=(1+9e^{2i\theta})(1+9e^{2i\theta})^{*}=82+18\cos{2\theta}[/tex], where * denotes the conjugate. Work out [tex]\theta[/tex] and you should see where the answer in your notes comes from. There's two choices of [tex]\theta\in[0,2\pi)[/tex] that give the max of |f(z)|.
Thanks very much for your help there, it really helped esp with the maximizing. :smile: I've just realized I've been messing the others up, like if we had the integral of e^(2z) divided by z^2 + 1. Do we do the same, like by taking the modulus of it as above and then working out the min value? I can't believe it slipped my mind how to find the modulus of a complex number. It actually took me to look at my quantum mechanics notes to figure that one out. I'm so dozey! I think I'm going to head off to bed now cos I've been awake for 19 hours and I'm generally a pretty snoozy person! Thanks again.
You can work out the max of [tex]|e^{2z}/(z^2+1)|[/tex] the same way as before (dealing with the square of the modulus will make things simpler again). This will be a large pain though.
If I wanted to find a bound for this integral, I would probably find the max of [tex]|e^{2z}|[/tex] on the circle and the max of [tex]|1/(z^2+1)|[/tex] on the circle, then multiply the values to get a bound for the modulus of the entire function. Using this bound rather than the maximum of the function won't give as tight a bound for the integral in the end, but not much will actually be lost and this kind of procedure is sufficient for most applications and *much* easier to apply.
You might want to work out both methods to see the difference. You might also want to work out the exact value of the integral to see just how off these bounds actually are. The results might be disconcerting, but rest assured that these kinds of lousy looking bounds are often more than enough.
I was just trying the first method and I wanted to know how we can find the conjugate of e^z? I know it sounds dozey but I really don't know. I mean I can do the conjugate of an ordinary complex number but not one where it's to the power of it. What we've got in our notes it stuff like (z1/z2)* gives us the conjugate of z1 over the conjugate of z2, but I don't kno how it works when we''ve got the exponential. Should the exponential be changed into another form?
If I did it the second way I'd have said that e^z would have been maximum at theta = 0, 2pi etc (only guessing though, I'm not sure how you could work this one out exactly) , but for the first one I wasn't sure...
Btw, for the second bit when you say multiply the 2 bounds together, do you mean divide? Like since z^2 + 1 is on the denominator?
Btw, sorry about all the questions, I guess I'm a bit dozey. Thanks again for your help - you're proving to be a lot more helpful than the recommended texts!
Suppose z = x + yi, then conjugate(e^z) = conj(e^(x + yi)) = e^x * conj(e^(yi)) = e^x * conj(cos(y) + isin(y)) = e^x(cos(y) - isin(y)) = e^x(cos(-y) + isin(-y)) = e^x * e^(-yi) = e^(x - yi) = e^(conj(z)).
Your intuition is correct here. Use [tex]e^{a+ib}=e^{a}(\cos(b)+i\sin(b))[/tex] to work out the modulus of e^z on the circle, where [tex]a+ib=z[/tex].
I meant maximum- sorry I did a change up and was talking about an upper bound for [tex]|1/(z^2+1)|[/tex]. If you had a lower bound for [tex]|z^2+1|[/tex], then you'd divide as you say. I should mention that you can use the triangle inequality to find a bound if you aren't concerned with the tightest bound possible. For example [tex]|z^2+1|\geq |z^2|-|1|=|z|^2-1=R^2-1[/tex] on the circle of radius R. This particular lower bound is only meaningful if R>1 though. In this case it does give the tightest bound, but this won't always happen.
Ah right, so I can have that if we have e^z and I change that so z=re^(itheta), and (e^z)* will give us e^(e^-(itheta))?
Btw, thanks for the heads up on the triangle inequality. :smile:
Anyhoo, I've been faffing about with finding the tightest possible upper bound for the closed integral of the modulus of (e^2z)/(z^2 +1)
I did the square of the modulus so I'm now looking at finding the maximum of (e^(12cos(theta)))/(82 + 18cos(2theta)) which I got after a bit of work, but now I'm a bit stuck and I'm not sure how much further to take it. I'm maybe seeing now why it'd be better to not have as tight an upper bound, but I'd just like to see if I can get this one to work. :smile:
Hi, you should be able to maximize that via the usual methods, differentiate w.r.t. theta, set=0, etc. It's a pain, but using some trig identities (a half angle formula and sin^2+cos^2=1 should do it), it should be feasible.
I handed it in with the more simple way so *fingers crossed* it comes out okay. I asked the lecturer the day before I was to hand it into see if he could give me a bit of feedback on how tight the bound had to be, but he just told me that I was the mathmatician and what did I think... not quite what I was hoping for but nevermind! Makes me thankful I found this place or sometimes I'm not sure how I'd get to grips with some of the material that we cover! :smile:
Speaking of integrals, I was hopign someone could give me a hint as to what I've to do to get the integral between 0 and + infinity of (sin^2x)/(x^2). I can integrate the same thing just without the squares in it by doing the whole method of using a semicircle with a little arch in the middle to avoid the singularity at 0, but I can't do this here because there comes a point in it where I end up with a completely up the left answer (when we have to let r, the radius of the little arch, go to zero and we have the integral around the small circle of (e^i2z)/(z^2). Normally when you change the variable you're left with something v.easy to integrate, but not here as you still have an r on the bottom so it shoots to infinity). I read a formula online for this kinda thing where the closed integral of f(z) = 2pi i(sum of enclosed residues)+ pi i (residues on the boundary) which works fine for mme, but this isn't something we're being taught so I was hoping someone else could give me a push in the right direction about this. If you want to seemy working out for what I've done so far feel free to say, as I'll put it up on a word document since I can use (shock, horror!) equation editor on that.
Decided just to write it up on word anyway so here's my working out (hope it appears!)
  • Consider the integral of the function.doc
Oh, and we've to show that it is equal to pi. :smile:
Are you opposed to using the Laurent series of [tex]\frac{1-e^{2iz}}{z^2}[/tex] at z=0 to find it's integral on your path a? This is what the +pi*i*(residue on boundary) kind of results you found would have used. It's not too difficult once you've found the Laurent series and ties in very nicely with the work you've been doing on bounding certain integrals.
So I suggest find the series and try to integrate it. A hint: the 1/z term is to be trated seperately, the rest of the series can be dealt with in one fell swoop. More hints available on request.
When I'm getting the Laurent series for this, do I expand e^(i2z) using the Talyler series? Well, the Maclaurin series really since z=0?
Okay, well this is what I've got so far from using the Laurent series (although I don't imagine it's right since I'm not too good at it!).
I've got the first 4 terms of the Talyer expansion to be
1+ 2iz - 2z^2 - (4/3)iz^3
So putting this back into what we had originally we get (-2i)/z + 2 + (4/3)iz
I'm not sure where to go from here though as I don't know how you can just integrate a few terms and get the right answer... I guess I'm just being a numpty here!
Btw, sorry to be a pain, but why does the 1/z term have to be treated separately from the rest?
Your Laurent series is looking correct. Try integrating the first 3 or 4 by themselves and see what happens to each as you let r->0.
You're right, there's an infinite number of terms, you'd have to integrate them all and sum up the results to get an answer, fortuneately there's an easier way. A key thing here is 1/z is unbounded as your circle gets smaller. Not so for the rest of the terms. In fact you can write:
[tex]\frac{1-e^{2iz}}{z^2}=-2i/z+h(z)[/tex]
where h(z) is analytic on some disc containing zero. This means it's bounded on the same disc. You can use this bound (and we won't care what it actually is, just that it exists) to estimate the size of the integral of h(z) on your curve, then let r->0 and see what happens.
What is a complex integral?
A complex integral is a mathematical concept that involves evaluating the integral of a complex-valued function. It is similar to a regular integral, but the function being integrated can take on complex values instead of just real values.
What is the difference between a complex integral and a regular integral?
The main difference between a complex integral and a regular integral is the type of function being integrated. A regular integral deals with real-valued functions, while a complex integral deals with complex-valued functions. Additionally, complex integrals can be more challenging to evaluate due to the properties of complex numbers.
How is a complex integral evaluated?
A complex integral is evaluated using techniques such as contour integration, Cauchy's integral theorem, and Cauchy's integral formula. These techniques involve using complex analysis to manipulate and simplify the function being integrated.
What are some applications of complex integrals?
Complex integrals have many applications in mathematics and physics. They are used in the study of complex functions, in solving differential equations, and in evaluating path integrals in quantum mechanics. They also have applications in engineering, such as in signal processing and control systems.
Is it important to understand complex integrals?
Yes, understanding complex integrals is important for anyone studying mathematics, physics, or engineering. They provide a powerful tool for solving problems involving complex functions and have numerous applications in various fields. Additionally, a thorough understanding of complex integrals is necessary for more advanced topics in complex analysis and theoretical physics.
  • Calculus
  • Calculus
  • Calculus
