Question about induced matrix norm
  • Context: Graduate
  • Thread starter Thread starter charlies1902
    Induced Matrix Norm
14 replies · 2K views
charlies1902
The induced matrix norm for a square matrix ##A## is defined as:
##\lVert A \rVert= sup\frac{\lVert Ax \rVert}{\lVert x \rVert}##
where ##\lVert x \rVert## is a vector norm.
sup = supremum
My question is: is the numerator ##\lVert Ax \rVert## a vector norm?
on Phys.org
sup = supremum
The same as in the denominator.
The denominator is a vector norm, so are we saying that the numerator is a vector norm for all square A matrices?
fresh_42 said:
##Ax## is a vector, so ##||Ax||## is a vector norm. It makes sense to choose the same.
Is this norm defined only for non-singular matrix A?
fresh_42 said:
It's defined for the whole vector space of linear transformations. It has to satisfy ##||A|| = 0 ⇒ A = 0##. It can't be more singular.
I see. I have a task to prove that the norm defined by the OP is indeed a norm. In your post (the quoted), that is one of the conditions, but I am not given if A is singular/nonsingular, so essentially I have to prove that A can't be singular in order for this to satisfy the criterion of a norm.
Is this an alternative explanation why A cannot be singular?
fresh_42 said:
The singularity, defect or rank have nothing to do with the defined norm to be one. The linear transformations may not even to be between vector spaces of the same dimension.
To start with: What do you know about your vector norm?
I know that a vector norm has to satisfy the 3 criteria:
1.
##\lVert x \rVert \geq 0##
##\lVert x \rVert \geq 0## = 0 IFF x = 0
2.
##\lVert constant*x \rVert = \mid constant \mid * \lVert x \rVert##
3.
##\lVert x+y \rVert \leq \lVert x \rVert+ \lVert y \rVert##
fresh_42 said:
So ##||Ax|| = 0## implies what for which ##x##? Similar the linearity. For the triangle inequality pull the factor ##||x||^{-1}## into the numerator.
Well the induced matrix norm is defined for ##x \neq 0##,
so ##x## can be any vector other than the zero vector.
But what if you have the matrix
A = \begin{bmatrix}
0 & 0 & 1\\
0 & 0 & 0\\
0 & 0 & 0\\
\end{bmatrix}
and
x = \begin{bmatrix}
1\\
0\\
\end{bmatrix}
Here we can see that A is singular, but Ax = 0, so the vector norm of Ax is satisfied, but A is not the zero matrix?
A = \begin{bmatrix}
0 & 0 & 1\\
0 & 0 & 0\\
0 & 0 & 0\\
\end{bmatrix}
and
x = \begin{bmatrix}
1\\
0\\
\end{bmatrix}
However, it's not the maximum / supremum choice for ##x##.
If the maximum is zero, then all are. The 'iff' condition on vector norms gives you ##Ax = 0## for all ##x ≠ 0##. For ##x=0## it's clearly also true. So ##A## has to be?
Oh I see. I disregarded the fact that Ax = 0 for ##\textbf{ALL}## ## x \neq 0##
In order to satisfy Ax=0 for all non-trivial x, A must be zero.
Right?
