Question about nth root of unity
  • Thread starter Thread starter mesa
    Root Unity
9 replies · 4K views
mesa
Determine the nth roots of unity by aid of the Argand diagram...
Is the nth root of unity where we have a complex number to the 'nth' power equal to 1? For example,
$$(2+i)^n=1$$
None yet, still trying to translate the question.
$$(2+i)^n=1$$
It's more like:
Solve zn = 1 for z , where z is complex.
Yes. For example, [itex]-\frac{1}{2} + i\frac{\sqrt{3}}{2}[/itex] is one of the 3rd roots of unity because [itex]\left(-\frac{1}{2} + i\frac{\sqrt{3}}{2}\right)^3 = 1[/itex].
$$(2+i)^n=1$$
In math in English, 'unity' is a quaint way of saying 'one'.
$$(2+i)^n=1$$
The only integer n for which this is true is n = 0.
2 + i is a complex number whose magnitude is √5. Multiplying it by itself is effectively rotating it by a certain amount, and increasing the magnitude. In polar form, this is easier to see.
2 + i = √5e, where θ = tan-1(1/2).
(2 + i)n = [√5e]n = (√5)neinθ
Okay, this makes much more sense now, so we are looking for x and y values that will have a magnitude (modulus z, or r) of 1 and we can use a generating function for complex numbers like so:
$$\left( \frac{1}{k} \right)+i\left( \frac{\sqrt{k^2-1}}{k} \right)$$
or this,
$$\left( \frac{\sqrt{k^2-1}}{k} \right)+i\left( \frac{1}{k} \right)$$
I worked really hard with Latex on those big parentheses only to decide I prefer them without :)
This looks really nice - I like the big parens - but I don't see how this is answers your original question. An nth root of unity is a complex number z, such that zn = 1. If you write z = 1e, then you have zn = 1neniθ.
My comment followed your question about whether (2 + i)n could equal 1.
the parenthesis are wrong... [itex]z^{n}≠|z|^{n}[/itex]
in other words, writing [itex]z^{2}[/itex] you mean [itex]zz[/itex] not [itex]zz^{*}[/itex]
So if you take the 2nd root for example (n=2) of the formula you provided:
[itex](\frac{1}{k}+i \frac{\sqrt{k^{2}-1}}{k})(\frac{1}{k}+i \frac{\sqrt{k^{2}-1}}{k})≠1[/itex]...
If you want to use the form for [itex]z=x+iy[/itex]
then
[itex](x+iy)^{n}=1[/itex]
can be terrible...but not impossible to show...
Using the Binomial theorem:
[itex](x+iy)= \sum_{k=0}^{n} (n k) x^{k} (iy)^{n-k}[/itex]
http://www.dummies.com/how-to/content/how-to-expand-a-binomial-that-contains-complex-num.html
and proceed accordingly...(probably you'll have to end up with sins and cos, as a taylor expansions?)
Of course that's totally tedious... it's faster to follow the already proposed idea of writing [itex]z=r e^{i\theta} (r=1)[/itex]
from the last you can also deduce that [itex]x^{2}+y^{2}=r^{2}=1[/itex]
or better put that [itex](x,y)[/itex] belong on the unitary "circle" (in fact it's a circle for n going to infinity, otherwise it's a "circle" created by n-points). So here again you see the sin,cos solutions (which must be on the complex plane)...
Thanks! Maybe they aren't so bad then :)
So I got this from your suggestions,
$$1=\cos \left( \frac{2Pik}{n} \right) + i\sin \left( \frac{2Pik}{n} \right)$$
What a remarkable answer, and so versatile! I used algebra to write another solution but so far have only been able to get one answer for the cubic.
SammyS said:
How is k related to n ?
It's not really, went off on a tangent :P
then
Yup, I messed up and was headed the wrong direction but have it now. I love binomial theorem, I wish they went over it in our engineering program, at least we have breaks for playing with such delightful things.
