Question about proof from a guy with a highschool education
The discussion revolves around understanding mathematical proofs, specifically how to present a proof for the statement that if A, B, and C are real numbers such that (A + B) = C, then (A - B) = (C - 2B). Participants explore the structure of proofs, the importance of justifying steps, and the need for axioms and lemmas.
  • One participant seeks guidance on how to present a proof and shares an initial attempt.
  • Another participant critiques the use of notation and emphasizes the need to state axioms and previously proven results explicitly.
  • Some participants suggest that the proof should start from accepted assumptions rather than working backwards.
  • There is a discussion about the necessity of justifying each step in the proof, particularly the transition from (A + B) = C to A = C - B.
  • Participants express confusion about what axioms to accept and how to present them in the context of the proof.
  • References to field axioms and their importance in justifying mathematical statements are made, with links provided for further reading.
Participants generally agree on the importance of justifying each step in a proof and the need to reference axioms. However, there is no consensus on the specific axioms to accept or how to present them, leading to ongoing questions and clarifications.
Some participants express uncertainty about the definitions and implications of axioms, indicating a need for clearer guidance on foundational concepts in mathematical proofs.
This discussion may be useful for individuals new to mathematical proofs, particularly those seeking to understand the structure and requirements of formal proof presentation in mathematics.
  • #511
micromass said:
No, that answer is incorrect. How did you find it??
Instead of just giving your answer, I really would appreciate it if you would also give a formal proof of why the answer is correct. For example, what Fredrik did in post 504.
I would like to be sure I'm reading the notation correctly at least.
Is it (a) × [all numbers between 0 and 1 , including both of them] ?
Mathematics news on Phys.org
  • #512
Yes, it's
[tex]\{a\}\times \{x\in \mathbb{R}~\vert~ 0\leq x\leq 1\}[/tex]
  • #513
Fredrik said:
The ##\times## in post #511 is a cartesian product.
I'm a little bit confused about how you can multiply a number with something like [0,1].I don't think I've ever encountered such a thing.
  • #514
micromass said:
Yes, it's
hmmm ok , let me think about it some more.
  • #515
We don't multiply a number with [0,1]. We take the cartesian product of the set ##\{a\}## (this is not a number, but a set containing the number) and the set [0,1].
  • #516
Okay ,my thought process was that since 1 is included , then all real numbers could be multiplied by 1 and it would give me all real numbers.Since it's the union of all these multiplications , I figured in the end it would be all real numbers present in the set.The other multiplication like (3) × 0,6 for exemple would just give me 1,8 , which is the same as (1,8) × 1.So they are all guaranteed to be there.
  • #517
But ##\times## isn't multiplication. It's the cartesian product.
  • #518
So the cartesian product would look like : ##( x \in R , 0 ≤ x ≤ 1)## ? (an ordered pair)
  • #519
The cartesian product of which sets would like like that? I don't understand the question.
  • #520
How about that? ##\{(x,y) \in R : x \in R \ \ , 0 ≤ y ≤ 1 \}##
  • #521
Is this supposed to be an answer to the question in 511?
In that case, can you please provide a formal proof of this. Like Fredrik did in 504.
  • #522
Yes , it's suppose to :smile:
Okay I will try to prove it.
  • #523
(x,y) is an element of the union of all cartesian products of ##\{a\} × [0,1]## with ##a## being an element of the set ##R##.
union: (x,y) is an element of at least one cartesian product of ##\{a\} × [0,1]## with ##a## being an element of the set ##R##.
##R## is the set of all real numbers.
Since it's ##\{a\} × [0,1]## , the first componant of every ordered pair of this set will be an element of ##R## and the second will be a number between 0 and 1 (with 0 and 1 included because of the [] ).Since all numbers between 0 and 1 are real numbers , then the second componant will also be an element of ##R##.
This means that ##(x,y) \in R## , and since ##x \in R## and ##0 ≤ y ≤ 1## , this set will be the set ##\{ (x,y) \in R : x \in R \ , 0 ≤ y ≤ 1\}##.
  • #524
This means that ##\{(x,y) \in R\ : ...\}## , and since ##x \in R## and ##0 ≤ y ≤ 1## , this set will be the set ##\{ (x,y) \in R : x \in R \ , 0 ≤ y ≤ 1\}##.
That only proves
[tex]\bigcup_{a\in \mathbb{R}} \{a\}\times [0,1]\subseteq \mathbb{R}\times [0,1][/tex]
You need ot prove the other inclusion too.
  • #525
micromass said:
That only proves
How could the first be a subset of the second? It should be the opposite no?
edit:forget it , they are the same aren't they?
  • #526
Let assume x is an element of ##\bigcup_{a\in \mathbb{R}} \{a\}## and that y is an element of [0,1].
This implies that ##(x,y) \in \bigcup_{a\in \mathbb{R}} \{a\}## × ##[0,1]##.
Now let assume ##(x,y) \in \bigcup_{a\in \mathbb{R}} \{a\}## × ##[0,1]## , this implies that ##x \in R## and that ##0 ≤ y ≤ 1##.Therefore it proves that this is the set ##\{ (x,y) \in \bigcup_{a\in \mathbb{R}} \{a\} × [0,1]: x \in R \ , 0 ≤ y ≤ 1\}##.
  • #527
I think it's almost time to start doing things a more normal way. I don't mind if you keep using the thread this way for the rest of the day (and night), but after that, I would like you to start using the homework forums for questions about textbook problems*.
You can keep using this thread for questions about definitions and theorems in the Book of Proof. When you start with calculus, you should start another thread to discuss concepts from your calculus book.
*) Note that we have specific guidelines about how to ask for homework help.
  • #528
Is what I'm missing the fact that the ordered pair will always be [R , 0] , [R , 0,002] , ... , [R , 1]. With R truly meaning all numbers in R?
This would mean : Now let assume ##(x,y) \in \bigcup_{a\in \mathbb{R}} \{a\}## × ##[0,1]## , this implies that ##x = R## and that ##0 ≤ y ≤ 1##.Therefore it proves that this is the set ##\{ (x,y) \in \bigcup_{a\in \mathbb{R}} \{a\}× [0,1] : x = R \ , 0 ≤ y ≤ 1\}##.
(The union of all elements of R = R.Which is why the x=R was implied)
  • #529
You can keep using this thread for questions about definitions and theorems in the Book of Proof. When you start with calculus, you should start another thread to discuss concepts from your calculus book.*) Note that we have specific guidelines about how to ask for homework help.
No problem.I think the thread has been more about questions and definitions than exercises anyway.I only tried exercises here and there to verify if I understood.
It wasn't my intention to make you guys correct a bunch of exercises for me.
  • #530
Since that union is equal to ##\mathbb R##, this is the same thing as assuming that ##(x,y)\in\mathbb R\times[0,1]##.
I would interpret the notation on the right here as
$$\bigcup_{a\in \mathbb{R}} \left(\{a\}\times [0,1]\right),$$ not as
$$\left(\bigcup_{a\in \mathbb{R}} \{a\}\right)\times [0,1].$$ The notation is kind of ambiguous though. I don't know if one of these interpretations are "standard". I'm also not sure how you're interpreting it.
You haven't proved that (x,y) is an element of the latter of these two sets, because that statement is your starting assumption.
And you haven't proved that (x,y) is an element of the former of the two sets either, but it's not hard to add a statement that takes care of that.
So let's be really clear here. Let's say that we want to prove that $$\bigcup_{a\in \mathbb{R}} \left(\{a\}\times [0,1]\right)=\mathbb R\times[0,1].$$ The parentheses make this problem unambiguous. This is how I would start:
Let ##z\in \bigcup_{a\in \mathbb{R}} \left(\{a\}\times [0,1]\right)## be arbitrary. Let x be an arbitrary real number such that ##z\in\{x\}\times [0,1]##. Let y be an arbitrary element of [0,1] such that ##z=(x,y)##. Since ##x\in R## and ##y\in[0,1]##, this equality implies that ##z\in\mathbb R\times [0,1]##. Edit: You know what, I'm going to rewrite this in an even clearer way. See below in a few minutes.
Can you do the other one, starting like this:
Let ##z\in\mathbb R## be arbitrary.
Edit: Here's the maximal clarity version of the proof above:
Let ##z\in \bigcup_{a\in \mathbb{R}} \left(\{a\}\times [0,1]\right)## be arbitrary. The definition of this notation implies that there's a ##b\in\mathbb R## such that ##z\in\{b\}\times[0,1]##. Let ##x## be such a real number. We have ##z\in\{x\}\times[0,1]##. The definition of this notation implies that there's a ##c\in[0,1]## such that ##z=(x,c)##. Let ##y## be such an element of [0,1]. We have ##z\in (x,y)##. Since ##x\in\mathbb R## and ##y\in[0,1]##, this implies that ##z\in\mathbb R\times[0,1]##.
  • #531
Just saw your edit lol Saved by the bell.
  • #532
Let ##z \in R × [0,1]## be arbitrary.This implies that there's an arbitrary element ##x \in R## and an arbitrary element ##y \in [0,1]##.The notation of the set implies that ##(x,y) = z##.Since ##y \in [0,1]## and ##x \in R## , that the union of all elements of ##R = R## , this implies that ##z \in \bigcup_{a \in R}\{a\} × [0,1]##.
  • #533
I'm done with the edit. My proof at the end is more detailed than the proofs you will find in textbooks. For example, I said "there's a real number b such that..." and then followed up with "let x be such a real number". Textbooks always smash these two statements into one. I think most of the authors choose to emphasize only the "there exists" part by saying "there's a real number x such that..." The problem with this is that when they refer to "x" in the next sentence, it's not really clear that they're referring to an x with the property just discussed, because the x in the "there exists" statement was a dummy variable.
So this way of presenting the proof is an abuse of language, but people use it anyway because it's a pain to have to think of a second variable to use and then make both statements.
What I did in my first version of the proof was to emphasize the assignment of a value to a new variable x instead of the "there exists" part. I often do that by saying something like "let x be a real number such that...". From a strictly logical perspective, this is better because now when the next sentence refers to x, there's no question of what x. But it may still be more difficult to understand, since it's now up to the reader to understand that the previous statement implies the existence of a real number with the necessary property.
So one thing I could have done is to add a comment after my "let x..." statement. For example: (The definition of "union" implies that such an x exists).
  • #534
Well, ##x## and ##y## aren't arbitrary anymore. They are completely determined by ##z##. So ##z=(x,y)## for a unique ##x## and ##y##.
  • #535
I'm not sure I understand , what am I suppose to say then? Just leave the word ''arbitrary'' out?
Should I say , R × [0,1] implies that z = (x,y)?
  • #536
Yeah, you shouldn't say that ##x## and ##y## are arbitrary, since they are completely determined. Only ##z## is arbitrary.
  • #537
Corrected version:
Let ##z \in R × [0,1]## be arbitrary.This implies that there's an element ##x \in R## and an element ##y \in [0,1]##.The notation of the set implies that ##z = (x,y)##.Since ##y \in [0,1]## and ##x \in R## , that the union of all elements of ##R = R## , this implies that ##z \in \bigcup_{a \in R}\{a\} × [0,1]##.
  • #538
Hmmm I see , I was wondering why you were doing that.I do ''get it'' , but it's harder to do than it looks when you read it and approve :smile:
thanks man!
  • #539
To be honest at the beginning I was wondering which one it was.
In the second one , does it mean that each ordered pair would look like [all real numbers , 1]?
  • #540
I had started typing this when my brother interrupted me with a phone call. I see that you are already working on these issues with micromass, but I might as well post it since I had finished this post before I saw that.
So far so good. :smile:
Either say "this implies that there's an ##x\in\mathbb R## such that..." or "let x be an arbitrary real number such that...". Don't say "implies that there's an arbitrary ##x\in\mathbb R##..."
More importantly, what you're saying here is just that ℝ and [0,1] are non-empty sets. They are, but, we didn't need to use the statement ##z \in\mathbb R × [0,1]## to see that.
You said that x,y,z were all arbitrary, so this doesn't follow from what you said.
  • · Replies 18 ·
  • · Replies 17 ·
11K
  • · Replies 77 ·
10K
  • · Replies 21 ·
