Question about proof from a guy with a highschool education
The discussion revolves around understanding mathematical proofs, specifically how to present a proof for the statement that if A, B, and C are real numbers such that (A + B) = C, then (A - B) = (C - 2B). Participants explore the structure of proofs, the importance of justifying steps, and the need for axioms and lemmas.
  • One participant seeks guidance on how to present a proof and shares an initial attempt.
  • Another participant critiques the use of notation and emphasizes the need to state axioms and previously proven results explicitly.
  • Some participants suggest that the proof should start from accepted assumptions rather than working backwards.
  • There is a discussion about the necessity of justifying each step in the proof, particularly the transition from (A + B) = C to A = C - B.
  • Participants express confusion about what axioms to accept and how to present them in the context of the proof.
  • References to field axioms and their importance in justifying mathematical statements are made, with links provided for further reading.
Participants generally agree on the importance of justifying each step in a proof and the need to reference axioms. However, there is no consensus on the specific axioms to accept or how to present them, leading to ongoing questions and clarifications.
Some participants express uncertainty about the definitions and implications of axioms, indicating a need for clearer guidance on foundational concepts in mathematical proofs.
This discussion may be useful for individuals new to mathematical proofs, particularly those seeking to understand the structure and requirements of formal proof presentation in mathematics.
  • #451
reenmachine said:
I shouldn't have included them since the notation was between ( ) and not [ ].
so ##\{x \in R -1 < x < 1 \}##
I'm still getting used to these notations , never heard of such a concept before.
OK, good!
Try to experiment with the notation a bit, it's the best way to get comfortable with it. So the above answer is (-1,1), for example.
Mathematics news on Phys.org
  • #452
micromass said:
OK, good!
Good!
It pisses me off because I'm having a lot of fun , but I have to leave for school (if I want to ace these high school math exams sooner than later).I'll be back in 2 or 3 hours to try the last two which seems trickier.
thanks a lot for the help , if you have time to take a quick look when I come back I'll try to solve them! :smile:
cheers!
  • #453
micromass said:
[tex]\bigcup_{x\in \mathbb{R}} (x,x+1)[/tex]
screw school it can wait a couple of minutes , I'm giving this one a shot right away.
##\{ y\in R : \exists x \in R \ x < y < (x+1) \}##
  • #454
reenmachine said:
Good!
cheers!
Have fun!
In the meanwhile, let me explain yet another notation. We also have things like this
[tex][a,+\infty) = \{x\in \mathbb{R}~\vert~a\leq x\}[/tex]
[tex](-\infty, a) = \{x\in \mathbb{R}~\vert x<a\}[/tex]
These are "half-rays" of real numbers. Try to draw them.
You can also make sense of things like ##(-\infty,a]## and such. But I think it's clear.
Again, the ##\infty## is just a symbol. It is not a real number so it is not included in the set. The bracket ")" should already indicate that we don't include ##\infty##. We might include infinity by writing things like ##[-\infty, a]##, but this notation is not used because ##-\infty## is not a number, so saying things like "including minus infinity" makes no sense. (actually, in higher mathematics, it does make sense, but I don't want to confuse you now. So just know that every time you encounter ##\infty##, it will just be a symbol and not an actual number. This will always be the case until you learn things like analysis).
I actually prefer the notation ##[a,\rightarrow ) ## instead of ##[a,+\infty)## since the former makes no reference to a non-existent infinity, so it is less confusing. But it is a notation that is rarely used, so I won't use it either.
Now you know this, can you find the following:
[tex]\bigcap_{n=1}^{+\infty} [n,+\infty)[/tex]
[tex]\bigcup_{n=1}^{+\infty} (-\infty,n)[/tex]
  • #455
Perfectly fine. But this set can be written a lot shorter. It is actually a very well-known set. Can you find which one it is? If you don't know, then just read it out loud. Then think which ##y\in \mathbb{R}## satisfy the condition or don't satisfy it.
  • #456
Well I would guess it's just the set ##R##
  • #457
Right!
  • #458
micromass said:
Right!
Kind of funny that to define R we would use R multiple times in it's own definition.
  • #459
Well, it's not a definition of ##\mathbb{R}##. A definition would not use ##\mathbb{R}## anywhere.
  • #460
I'm already back , teacher called in sick so I came back.I'm learning more here than at school anyway.
  • #461
micromass said:
Have fun!
I'm not sure I understand , in the first one , you have ##[a## and ##\infty+)## , what if ##x = 4## and ##a = 2## , this would satisfy ##\{x\in \mathbb{R}~\vert~a\leq x\}## yet would not satisfy ##\infty+)## since all positive numbers are excluded.
Or does ##[a,+\infty)## automatically qualify ##a## as 0 or a negative number? But if it does , how do you know by simply reading the notation ##\{x\in \mathbb{R}~\vert~a\leq x\}##?
EDIT: I think I just understood , ##\infty+## isn't all positive numbers , it's just all numbers going in the positive direction starting from ##a##? Does ##a## counts?
  • #462
Why do you think all positive numbers are excluded. All ##[a,+\infty)## means is the set I wrote down.
  • #463
see edit
  • #464
Correct, ##[a,+\infty)## is all number starting from a (with a included, going in the positive direction). But it's ##+\infty## and not ##\infty+##.
If you don't want to include a, then it's ##(a,+\infty)##.
Again, ##\infty## is just a symbol. It has no meaning.
  • #465
But in ##[a,+\infty)## , you exclude all larger numbers than ##a## (and ##a##) from the set no? Because of the '')''.
So in ##\{x \in R : a ≤ x \}## , this is the set of all larger or equal numbers to ##a##.I thought these were the numbers that we excluded.
  • #466
No. You're interpreting the notation somehow. The ")" in the notation does not mean "excluding" something (unlike in the other [a,b) notation). Here the notation is just defined as
The ")" doesn't mean anything specific here.
If you want to understand the notation as "excluding" something,then you can see it as follows. Denote ##+\infty## as something (that is not a real number!) that is somehow larger than all real numbers. So ##2<+\infty## holds and ##10000000000<+\infty## holds. In fact, if ##x## is any real number, then ##x<+\infty## holds. The notation ##[a,+\infty)## just means all real numbers ##x## such that ##a\leq x<+\infty##. So we exclude the "thing" ##+\infty##. But since ##x<+\infty## holds for any real number ##x##, we just write ##a\leq x##. So if you want, you can interpret ##[a,+\infty)## as excluding a thing called ##+\infty## that is larger than all real numbers. This interpretation is problematic since it is not clear what ##+\infty## actually is. It is not a real number (by definition), but something else.
  • #467
Ok , I think I understand it , but one thing that confuses me is what happens if ##[a , +\infty]## instead of ##[a +\infty)## ?
This is the set of ##a## , every larger real numbers and even the ''thing'' that is larger than real numbers?
  • #468
reenmachine said:
Ok , I think I understand it , but one thing that confuses me is what happens if ##[a , +\infty]## ?
This is the set of ##a## , any larger real numbers and even the ''thing'' that is larger than real numbers?
Yes, that would be exactly what you describe.
But since the "thing" is not a real number itself, the set ##[a,+\infty]## would not be a subset of the real numbers. So if we only care about real numbers (like usual in calculus), then the set ##[a,+\infty]## is never used.
So although you can give meaning to ##[a,+\infty]##, you will never see it used (except if you get to advanced math courses). The only sets you will see used is ##[a,+\infty)##.
  • #469
Yes I intuitively figured this set wouldn't be used that often , if ever.
thanks a lot man!
  • #470
micromass said:
[tex]\bigcap_{A\in \mathcal{P}(\mathbb{R})} A[/tex]
Maybe something went over my head as I was thinking about this one , but could this simply be ##\mathcal{P}(\mathbb{R})##?
The intersection of all elements of ##\mathcal{P}(\mathbb{R})## is ##\mathcal{P}(\mathbb{R})##?
  • #471
That's not correct.
  • #472
Hmmm wait , ##A \subset R## , so ##A \in \mathcal{P}(\mathbb{R})##.
If ##R## was to be ##\{1,2\}##
##\mathcal{P}(\mathbb{R})## would be ##\{ \varnothing , \{1\} , \{2\}, \{1,2\}\}##.
These elements would originally comes from ##R## , but the problem is that they weren't elements but subsets.So that's why I'm hesitant before going with the answer ''##R##''.
  • #473
reenmachine said:
##\{ \varnothing , \{1\} , \{2\}, \{1,2\} , \{1,\varnothing\} , \{2,\varnothing\} , \{1,2,\varnothing\}\}##.
This is not ##\mathcal{P}(\{1,2\})## :confused:
Anyway, ##\mathbb{R}## is the wrong answer.
  • #474
I was in the moon.
there you go
  • #475
OK, so let ##E= \{1,2\}##. Can you find
[tex]\bigcap_{A\in \mathbb{P}(E)} A[/tex]
This is the same as
[tex]\emptyset \cap \{1\} \cap \{2\} \cap \{1,2\}[/tex]
  • #476
I don't mean to interfere with the discussion, which seems to be going well. Just a little observation: You seem to sometimes be confusing unions with intersections. Intersections give us something smaller, unions something bigger: $$A\cap B\subseteq A\subseteq A\cup B.$$
  • #477
This is the same as
1 and 2?
I admit I'm a bit confused :smile:
  • #478
reenmachine said:
1 and 2?
I really don't understand how you got this.
  • #479
Can the empty side intersect with anything anyway? In this case this would be the empty set?
How could nothing intersect with something.
  • #480
Why not??
What is ##\emptyset \cap A##?? Apply the definition of the intersection.
Yes, but you should really try to understand why your previous answers were wrong and this is right.
  • · Replies 18 ·
  • · Replies 17 ·
11K
  • · Replies 77 ·
10K
  • · Replies 21 ·
