Question about Static Friction
The discussion centers on the confusion surrounding the minimum force required to overcome static friction and initiate motion. It is clarified that when the pushing force equals the maximum static friction (Fsmax), the object begins to move, transitioning to kinetic friction. The importance of understanding the definitions of static and dynamic coefficients of friction is emphasized for better comprehension. Participants suggest that the original poster should improve their search skills to find reliable information. Overall, the conversation aims to clarify the mechanics of friction and encourage self-sufficiency in finding answers.
Krasz
Okay, I have been coming across a lot of problems that share something in common; They all ask what is the minimum amount of force required to move the object. Alright, so I've been looking all over the internet and have been finding varying answers from If the Pushing force (P) equals Fsmax, then the object starts moving. Is that true? When you equal Fsmax in force does it change to kinetic friction, hence the motion. Or when it equals Fsmax do you remain at rest? These problems are really annoying me due to the fact I don't know how to set up equations of friction to find the minimal force! Thanks for taking the time to read this! :)
How about you quote us the definitions of the static and dynamic coefficients of friction? And please give us links to where you found the information. Then, if you still have questions after answering your own questions, we will be happy to help.
EDIT -- not trying to sound like a mean guy here. Just wanting to make sure you are using the right search terms in your searches to answer your question, and making sure that you start to get better at answering your own questions using automated Internet search engines. I do it dozens of times a day in my work, and that's what you should be teaching yourself to be able to do...
Never have i heard of such an interesting "view" of static friction.
Well, I think they just mean that the static friction force is what you have to overcome to break an object loose to start it sliding.
For simple comparison, I think the same thought process can be followed as a block slides down a hill, - for block down hill, simple starting PE of mgh to final max KE 0.5mv^2 - comparing PE1 to max KE2 would result in finding the work friction did through the process. efficiency is just 100*KE2/PE1. If a mousetrap car travels along a flat surface, a starting PE of 0.5 k th^2 can be measured and maximum velocity of the car can also be measured. If energy efficiency is defined by...
  • · Replies 21 ·
  • · Replies 21 ·
  • · Replies 23 ·
  • · Replies 16 ·
  • · Replies 35 ·
