What is the maximum velocity of object A if its weight is doubled?
  • Context: High School
  • Thread starter Thread starter BeefSteak
    Velocity
The maximum velocity of object A, initially at 50 mph with a weight of 100 lbs, is influenced by the forces acting upon it, particularly air drag and rolling resistance. Doubling the weight to 200 lbs necessitates greater force to achieve the same velocity, as described by Newton's Second Law. The air drag force increases exponentially with velocity, while rolling resistance remains constant, dependent on mass and the coefficient of rolling resistance. Without specific vehicle details, the exact impact on maximum velocity remains indeterminate, but it is unlikely to drop below half of the original speed.
  • Understanding of Newton's Second Law of Motion
  • Knowledge of kinetic energy formula KE = 1/2(mv^2)
  • Familiarity with drag forces: air drag and rolling resistance
  • Basic principles of vehicle dynamics and physics
  • Study the effects of air drag on vehicle speed
  • Learn about rolling resistance and its calculation
  • Explore Newton's laws in the context of vehicle acceleration
  • Investigate the relationship between mass, force, and velocity in physics
Physics students, automotive engineers, and anyone interested in understanding vehicle dynamics and the factors affecting maximum speed.
BeefSteak
I was thinking of an object let's say object A has a maximum velocity of 50mph and weighs 100lbs if I added another 100lbs what would be the maximum velocity of the object A? I also want to know what topic is this concern for me to study and enable myself to answer this types of question.So I was thinkg KE = 1/2(mv^2)
Velocity isn't determined by mass, so the question isn't really sensible. The only limit on the velocity is the speed of light. It takes a force to increase the velocity of an object, and the faster you want to go and the heavier an object is the more force you need to get to that point. So doubling the mass would simply mean you'd need more Force to accelerate the object to get to 50 mph. This is the whole idea behind Newton's Second Law.
Hi, BeefSteak, I hope you did not let yourself frighten away . Welcome to PF! This is a good place, if you stick to the rules. You are offered a template when you start a thread, and you must not delete it.
I wonder what your question really is. What do you mean on maximum velocity? Please, copy the whole problem text.
A (wheeled) vehicle has two drag forces limiting its top speed.
(level ground assumed)
1) air drag force, which increases (exponentially) with velocity.
2) rolling resistance drag force which is deemed to be constant regardless of velocity, and depends on :
mass (m) in kg
local gravity rate (g) (9.81 m/s/s is usual)
tyre to road rolling resistance co-efficient (Crr) (0.03 is a good figure)
Assuming all the tyres are the same, the rolling resistance drag force (f) in Newtons you get from :
f = m * g * Crr
An exponential increase would be very unusual, for typical vehicles and the given speed a quadratic dependence is a much better approximation.
Without more details of the vehicle, we cannot tell which influence is more important, and we also don't know what limited the speed before. It is unlikely (but not impossible) that the vehicle will be able to become faster, it is unlikely that its top speed will go down below half of the original value, but everything in between is possible.
  • · Replies 35 ·
  • · Replies 20 ·
