Question: milikan experiment photoelectric effect
The discussion centers on the Millikan experiment related to the photoelectric effect, specifically addressing the work function of sodium (Na). The threshold frequency for electron ejection is noted as 43.9 x 1013 Hz, corresponding to an energy of 1.82 eV. However, historical data shows variations in the work function of sodium, ranging from 1.82 eV to as high as 2.75 eV due to advancements in experimental precision. The conversation highlights the evolving nature of scientific measurements and the importance of context in interpreting experimental results.
  • Understanding of the photoelectric effect
  • Familiarity with the concept of work function
  • Basic knowledge of frequency and energy calculations (E=hf)
  • Awareness of historical context in experimental physics
  • Research the historical variations in the work function of sodium (Na)
  • Study the principles of the photoelectric effect in detail
  • Examine advancements in experimental techniques in condensed matter physics
  • Explore the implications of purity and surface conditions on work function measurements
Students of physics, particularly those studying modern physics and the photoelectric effect, as well as researchers in condensed matter physics and materials science.
pepe1964
Hi, I'm a newbie starting to study physics at a later age (45).
I've tried to find an answer to my question in this forum, the internet , books, etc... already.
I'm reading Modern Physics, Tipler & LLewelyn. On p. 139 he presents a diagram illustrating Millikans experiment on work function (photoelectric effect). I've seen this same diagram on numerous other physics websites.
(eg. http://hyperphysics.phy-astr.gsu.edu/hbase/mod2.html#c3"
The threshold frequency of the incident light for an electron of the cathode to be ejected is -in this particular experiment- 43.9 *10^13 Hz.
Now, this corresponds to an energy of E=hf = 43.9 * 10^13 s-1 * 4.136*10^-15 eV s = 1.82 eV
Now my question: which element (metal) was this? Which material has a work function of 1.82 eV? I can't find any.
Am I messing up on this? I'm really stuck. Can someone bring some clarity?
I believe it was sodium (Na). However, experiments constantly refine our knowledge of materials (take AMO and Condensed Matter fields for example). Sometimes you will find Na quoted at 1.82, then higher as you found. Take this paper from the 70s for example. The research showed a jump from at the time 2.25 to 2.75 for the Na work function. As experimental devices become more precise, so does our data. I'm not an expert on this particular experiment (I wasn't around then), but hopefully this helps.:
http://prola.aps.org/pagegif/PRL/v26/i7/p380_1/p381
Many thanks Physicsdruid,
The link requires authorization however. Is there a way to send me the article as such?
After the many replies to my question (in the homework section), I began to have doubts again: the 1.82 is much LOWER than any other data available. If the metal surface was unpure (or whatever bias), the value should have been at least HIGHER than the modern data available...
Thanks again.
  • · Replies 25 ·
12K
