Question on finite and geometric series
The forum discussion focuses on solving two mathematical problems involving finite and geometric series. The first problem requires finding the exact sum of the series represented as S sub n = (2 + 2 + 2(2 + ... + 64), which is identified as a geometric series with a common ratio of √2. The second problem demonstrates that the sum of the first 10 terms of the geometric series 1 + 1/3 + 1/9 + 1/27 is twice the sum of the first 10 terms of the alternating series 1 - 1/3 + 1/9 - 1/27. The relevant formula for the sum of a geometric series is provided: S = a(1 - r^(n+1)) / (1 - r).
  • Understanding of geometric series and their properties
  • Familiarity with the formula for the sum of a geometric series
  • Basic knowledge of series notation and summation
  • Ability to manipulate algebraic expressions involving radicals
  • Study the derivation of the geometric series sum formula: S = a(1 - r^(n+1)) / (1 - r)
  • Explore examples of finite geometric series with varying common ratios
  • Learn about the convergence of infinite geometric series
  • Practice solving problems involving series notation and ellipses in mathematical expressions
Students studying pre-calculus or calculus, educators teaching series and sequences, and anyone looking to enhance their understanding of geometric series and their applications in mathematics.
Luceian K
1. 1. Find the exact(no approximations)sum for the finite series
S sub n= (2 + 2 + 2(2+...+64
i used the parentheses to represent a radical sign
2. Show that the sum of the first 10 terms of the geometric series
1 + 1/3 + 1/9 + 1/27+...
is twice the sum of the first 10 terms of the series
1 - 1/3 + 1/9 - 1/27+...
2. no relevant equations to solve this.
3. I attempted to solve this by dividing n/2(a sub 1 +a sub n). n would equal 64 and a sub one would equal radical 2 so 64/2 (radical 2 +64).
This is as far as I have been able to get and am not sure if it is the correct way to solve these two problems. I would appreciate if someone could show me step by step how to go about these since my pre-calc book does horribly at it.
So that is n= \sqrt{2+ 2+ 2\sqrt{2+ ...+ 64}}?
What does the "..." represent?
I would think that
\sum_{i=0}^n r^i= \frac{1- r^{n+1}}{1- r}
would be a very relevant equation!
the "+...+64" is not under the radical sign. Just 2)2. and the "..." is in the question, I don't know what it stands for. I am at a complete loss with these two questions. and my math book doesn't go into enough detail with these types of equations.
Is this S_n= \sqrt{2} + 2 + 2\sqrt{2}+...+64 = \sum_{1\le k \le 12} 2^{k/2} ?
if so, then it's a geometric series. Do you know the closed form of the sum of a geometric series?
If not, here's how to get it
S = a + ax + ax^2 + ... + ax^n = \sum_{0 \le k \le n} ax^k
Sx = ax + ax^2 + ax^3 + ... + ax^{n+1}
S - Sx = S(1-x) = a- ax^{n+1}
so S = a\frac{1-x^{n+1}}{1-x}
so the equation would not be n/2(a sub 1 + a sub n)
I would think that
for the second problem could you tell me how to find r i am unsure of how to solve for that variable
Sorry but I don't understand what you're asking. You don't have to solve for anything, just set r=\sqrt{2} (or x=\sqrt{2} in my post) because a=1 in your equation.
then i am not sure what n would be in the equation you have there.
Well I guess that's the problem. Ellipses mean that you follow the pattern that has been set until you get to 64 (in this case).
For example 2+4+8+16+...+512 is shorthand for 2+4+8+16+32+64+128+256+512.
In your problem, the patter is that the next term in the series is generated by multiplying the previous term by \sqrt{2}
the final term in a geometric series can be written in the form ax^n for some number n. The equation which you have is
\sqrt{2} + (\sqrt{2})^2+ (\sqrt{2})^3+ ... + (\sqrt{2})^{12}
So n=12
i got 216.09545 is this correct
Yes, that's correct. Now try the other problem.
thank you for your help
  • · Replies 22 ·
