Understanding Reflectance with Fresnel Equation for Non-Polarized Light
  • Context: Graduate
  • Thread starter Thread starter tanveers
    Fresnel
The discussion focuses on using the Fresnel Equation to determine reflectance for non-polarized light incident on a dielectric interface, specifically in the context of carbon nanotubes. The user seeks to predict reflectance as the angle φ varies continuously from 0 to 90 degrees, transitioning between S (perpendicular) and P (parallel) polarizations. The solution involves decomposing the laser polarization into its S and P components and analyzing them separately to calculate reflectance at various angles.
  • Understanding of the Fresnel Equation for light reflection
  • Knowledge of polarization states of light (S and P polarization)
  • Familiarity with dielectric interfaces in optics
  • Basic principles of light behavior in materials, particularly carbon nanotubes
  • Study the mathematical derivation of the Fresnel Equation for both S and P polarizations
  • Learn about the decomposition of light into S and P components
  • Explore experimental setups for measuring reflectance in optics
  • Investigate applications of carbon nanotubes in photonics and their optical properties
Researchers in optics, physicists studying light-matter interactions, and engineers working with carbon nanotubes and dielectric materials will benefit from this discussion.
tanveers
Hi All,
I am new to this forum. We are researching light reflection from carbon nanotubes. Now I know about the Fresnel Equation that can be used to determine reflectance for S (perpendicular to the plane of the incident) and P (parallel to the plane of the incident) polarized light.Now, if I want to know reflectance from a dielectric interface of light beam which is neither S nor P polarized rather it is in between. I would like to make it clearer. Please refer to the attached figure which shows our experimental setup. Now if we change the angle φ between 0 and 90 degree then they are basically representing P and S polarization respectively and the reflectance from the sample can be predicted using Fresnel equation. However if the variation of φ is continuous from 0 to 90 degree how do I predict the reflectance? Let's say φ = 10, 20, 30,…..90. Thanks a lot in advance.
Science news on Phys.org
Then decompose the laser polarization into S and P components and analyze them separately.
9K
