Question on nonlinear dynamics
The discussion revolves around the existence of a stable T-periodic solution for the system x' + x = F(t), where F is a smooth, T-periodic function. One participant believes that a T-periodic solution must exist and proposes to eliminate the time parameter to analyze the system as a 2D system. They plan to use a Poincaré map to demonstrate the periodicity of the solution. Another participant suggests considering a Fourier expansion as an alternative approach. The conversation highlights the need for further exploration of the proposed methods to confirm the existence of the periodic solution.
JuanYsimura
Consider the system x' + x = F(t), where F is smooth, T-periodic function. IS it true that the system necessarily has a stable T-periodic solution x(t)? If so, Prove it; If not, find an F that provides a counterexample.
x' + x = F(t)
So, I think this system necessarily have a T-periodic solution x(t). To prove it, I let y = t so i can eliminate the time parameter from the equation so then I get a 2D system
x' = F(y) - x
y' = 1
SO, then I plan to find a poincare map so that showing that x(t) is T-periodic.
MY question is, before I go further, is this a good approach to the problem?
thanks.
could you consider a Fourier expansion?
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
